Drivetrain Crank pulley survey
Old Apr 4, 2006 | 05:20 AM
  #51
MINIotaple's Avatar
MINIotaple
Originally Posted by mdsbrain
I think from our survey this simply shows that more study must be done on this part. Just that maybe more of a better How-to with a better explanation is needed.
This is what I've been wondering. Is it possible that all the problems seen from the crank pulley are due to faulty installation by an amateur?
Old Apr 4, 2006 | 05:27 AM
  #52
mdsbrain's Avatar
mdsbrain
But in my car's case I believe its a tranny related issue. The fact about the shifts and the ecu not keeping up. Not a problem with the installer as my installer has probaly done more crank pulley installs then anyway.
Old Apr 4, 2006 | 11:19 PM
  #53
AZMCS's Avatar
AZMCS
Bump. Come on folks, get your ballot in!
Old Apr 5, 2006 | 03:10 AM
  #54
etalj's Avatar
etalj
yeh this is understandable. This probably isn't too bad a fault to have, its the vibrations caused by an undamped pulley that i think is the serious problem with crank pulleys
Old Apr 5, 2006 | 09:53 AM
  #55
S_Hapens's Avatar
S_Hapens
19% Alta S/C with 0% alta light weight crank
Belt Snapped after about 20,000mi. after missing a gear taking it to redline and beyond. The alta crank pulley was trashed after the idler pulley limit stop snapped clean off, i replaced the belt and now on the second 0% alta crank pulley. I inspect the belt frequently and have replaced it twice since the incident. Seems to me with a better limit stop there would only be the problem of snapping belts.
Old Apr 5, 2006 | 09:57 AM
  #56
MINIotaple's Avatar
MINIotaple
... Is that a SC pulley or crank pulley problem?
Old Apr 5, 2006 | 10:17 AM
  #57
maxmini's Avatar
maxmini
I have seen a idler pulley limiter being sold in a few places for about $25. Looks like this might be a good invertment.
Randy
m7 Tuning
Old Apr 5, 2006 | 10:24 AM
  #58
SheaJeff's Avatar
SheaJeff
How come no one has an Alta 3% pully?
It seems like the max was 2%. What do I need to learn to understand this more?
Old Apr 5, 2006 | 10:27 AM
  #59
mdsbrain's Avatar
mdsbrain
Or the 1% or very few of the 0%. Reason being is people either go big with 2% or 4%. So they get roughly a 17% or a 19% reduction with a 15% pulley.
Old Apr 5, 2006 | 10:32 AM
  #60
SheaJeff's Avatar
SheaJeff
I have the JCW package (no idea about the SC pulley). Any recommendations on whether or not to get a crank pulley? What size?
Old Apr 5, 2006 | 10:36 AM
  #61
mdsbrain's Avatar
mdsbrain
This question can be answered by many folks in many different ways.
From what I have read, the common answers are this:
JCW pulley size is 14-15% reduction (depends on who you ask)
People usually do a 2% reduction pulley on JCW cars from what I've seen.
Old Apr 5, 2006 | 04:02 PM
  #62
skuzy's Avatar
skuzy
or they go for a 17% pulley instead. and keep the stock crank.
Old Apr 5, 2006 | 06:23 PM
  #63
jonnieoh's Avatar
jonnieoh
I have an ET 15% reduced supercharger pulley. I had it installed by the man, the myth, the legend, Randy Webb at one of his patented pulley parties in early November of 2005.
Not long, mind you, but there have been no problems so far!!! I'm more than satisfied with it.
Randy showed me both the ET and an Alta at the same time, and they were identical in every way, except the logos engraved on them.
Old Apr 5, 2006 | 07:01 PM
  #64
SteveS's Avatar
SteveS
there's one in every crowd they say. Well, here goes:
35,000 mi on car now.
at 3500, Randy inst. 15% pulley, no problems at all
30,500 installed 2% Alta pulley. Non-Mini guy did it. There was immediate slight vibration/rattle and roughness at low revs, like at takeoff or lugging engine.
32.500 new belt tensioner installed. (on warranty).This reduced the vibration a little. but it was still there and a concern.
34,000 I personally Ireinstalled a 2005 stock crank pulley that Randy gave me.
This made the car smooth like it used to be. I prefer the smoothness over the slight performance improvement.
No "problems" in that no breakdown , and maybe the mechanic tweaked the tensioner assembly since he probably did not have the proper tool to reduce tension on the pulley. Maybe my car is just sensitive and it does need the damper. I really wanted the Alta Pulley to work out.
BTW, I have the MTH program which has the quick return to idle, so the additional mass of the pulley does not keep the revs up like the stock ECU does.
I have OBX header (installed after stock crank pulley re-installed) and it does cause some roughness and resonance at low revs, but it is not as intrusive or vibrational in nature. The OBX makes the car really sound good and gives it a little more pep above 5,000.
Old Apr 5, 2006 | 08:03 PM
  #65
///ACS330Ci's Avatar
///ACS330Ci
Your dealer didn't give you any flack about the aftermarket crank pulley???
Old Apr 5, 2006 | 08:13 PM
  #66
Android993's Avatar
Android993
M7 16% and Alta 2% no problems at 7500 miles. Did the conversion at 2200 miles. Also have an Alta 0% crank pulley available for sale 300 miles on it perfect shape. $100 with free shipping. Pics available. PM if interested.
Old Apr 5, 2006 | 08:54 PM
  #67
skuzy's Avatar
skuzy
when fitting the crank did u have to 'run in' the crank? or no.
and is running a 15/2 set equivalennt to runnig a 17/0 setup? randy rekons 15/2 is good but is that the same as 17/0?
Old Apr 6, 2006 | 03:52 AM
  #68
mdsbrain's Avatar
mdsbrain
I haven't heard of anyone having to run-in any pullies.
Randy reccomends a 15/2 combo because it is easier on the belt. A 15/2 combo is very close to 17. I think I saw someone do the math and its like 16.8%.
Old Apr 6, 2006 | 02:40 PM
  #69
SteveS's Avatar
SteveS
I try not to get into any run-ins with animate or inanimate objects.
No issue with warranty. Shouldn't be a problem anyway since smaller pulley = less tension on tensioner.
It may be I'm just sensitive about changes to the car. I do suspect that the vibration/harshness resulting from the solid crank pulley would affect the accessories (supercharger) driven off the belt if allowed to persist too long. I don't think it is a matter of crank bearings or engine balance.
I don't think the pulley was defective in any way. It just didn't wonk for me.
Old Apr 6, 2006 | 04:52 PM
  #70
04SDmini's Avatar
04SDmini
I've got the 15/2 combo and love it. good bump up in power and quick response. No problem with it
Old Apr 6, 2006 | 05:45 PM
  #71
MINIotaple's Avatar
MINIotaple
I think you missed a couple of things, brand and mileage.
Old Apr 6, 2006 | 06:25 PM
  #72
skuzy's Avatar
skuzy
And how hard u drive the car (redline etc)
Old Apr 6, 2006 | 07:16 PM
  #73
04SDmini's Avatar
04SDmini
Oops...
Alta/Alta, Drive hard 50% of the time in traffic the other 50% and just under 10K on both
Old Feb 15, 2007 | 02:06 PM
  #74
MINIotaple's Avatar
MINIotaple
Link to post
Originally Posted by maxmini
Sorry about the delay but we wanted to have all of our ducks in a row on this one . In testing the M62 we discovered a entirely new issue . We have joined the ranks of a few cars that have discovered that high RPM and light weight crank pulleys do not play well together . I have a red line of 7200 and have not had a issue and I have many miles on this as it was our first unit built. Based on this recent development we are cautioning anyone with raised rev limits to be cautious when thinking about lightweight crank pulleys.The car in question has a custom software pkg which allows for a red line of 8250 RPM and the car has hit that many times in the months prior to the m62 install. Well to be specific the oil pump gear decided it had enough and let go thankfully at idle but some pieces bounced around in the oil pan, got into the crank and took out a piston which put a hurt on some of the internals. The motor is being rebuilt as we speak and we hope to have more info as soon as possible. Again sorry for the delay but we wanted to do a through post mortem and make absolutely sure it was not M62 related.
Randy
M7 Tuning
Old Feb 15, 2007 | 02:36 PM
  #75
maxmini's Avatar
maxmini
Thanks for posting this over here as well and helping get the word out. We feel that if you are running custom software with a higher rev limit you should think twice about a lightweight pulley . I get into the 7k range now and then with no issues but for those of you really pushing it we would caution you with regards to any un dampened pulley.
Randy
M7 Tuning
