Drivetrain Are you boosting over 18psi???
Old Mar 12, 2006 | 07:23 PM
  #26
dominicminicoopers's Avatar
dominicminicoopers
Originally Posted by Johan
I have the same problem. My DSC light will come on, and if I really overboost the SES light will come on. P0108 see it every day! I'm sure that the twin charge guys have something to over-ride this sensor! -- Johan
I'm one of the twincharge guys and I'm not getting this DSC light on higher PSIs. I used to get this when I had an exhaust leak right by the downpipe, and it was blowing hot exhuast gases directly onto the DSC unit and it's associated lines. Once the exhaust leak was fixed, then the DSC light coming on hasn't been a problem. I do have a continuous SES light on...probably a combination of the overboost condition and the o2 readings being off.
Old Mar 12, 2006 | 07:48 PM
  #27
MSFIT's Avatar
MSFIT
I can try VGS sometime this week, I'll let you know if it makes any difference.
Old Mar 12, 2006 | 08:06 PM
  #28
Barnabas's Avatar
Barnabas
Originally Posted by 002
msfit, search around, I've read other posts of this happening. Check with mth, I think they are able to programme new parameters.
Barnabas, the map at 36psi is absolute pressure, so about 20 psi could be a problem, although I've heard that 18psi is when people start seeing the dsc light.
Oop you're correct! And it makes more sense haha Thanks for the correction
Old Mar 12, 2006 | 08:11 PM
  #29
Barnabas's Avatar
Barnabas
That's interesting. It makes sense... High boost results in high exhaust pressures and temperatures which can result in exhaust leaks. I like your explanation since it doesn't make sense why DSC would go off due to a MAP sensor reading.
Old Mar 13, 2006 | 01:53 PM
  #30
Cupid's Avatar
Cupid
I had %17 pulley and get this error, so I hit with the %15 and I still have it in the upper revs.. Especially about 215km/h in the 5th, I always get it.. I got superchips and they can't fix it.. Roads in Turkey are really bad so I need DSC in the high speeds..
Old Mar 13, 2006 | 05:49 PM
  #31
Johan's Avatar
Johan
Originally Posted by Barnabas
Are you able to extract any code due to the DSC light? That'd make life alot easier when trying to figure out why it's throwing the light. I'll look into the DSC issue tomorrow..very puzzling
Yes P0108. The DSC light will come on and stay on. I can't turn it off until I shut the car off and re-start. Since I installed a light weight crank pulley (0%) sometimes my SES light will come on as well as DSC. P0108 I may be hitting 19 at the gauge, but 18 for sure. -- Johan
Old Mar 13, 2006 | 08:53 PM
  #32
Barnabas's Avatar
Barnabas
Ok let me get this straight...The P0108 is associated w/ the DSC light staying on? So P0108 isn't related to the SES light?
EDIT: Or at least P0108 doesn't necessarily mean SES light?
Old Mar 14, 2006 | 06:09 AM
  #33
Johan's Avatar
Johan
wrong...P0108 is associated with the DSC and SES. It will throw 2 codes, both P0108.
right...P0108 doesn't necessarily mean SES light. For me, may be different for someone else.
  #34
RED FURY's Avatar
RED FURY
MSFIT ....
What mods have you added since Laguna Seca ? You holdin out on me ?
Old Mar 14, 2006 | 07:19 AM
  #35
Barnabas's Avatar
Barnabas
When just the DSC light comes on, does it only store a single P0108 code?
Old Mar 14, 2006 | 07:35 AM
  #36
MSFIT's Avatar
MSFIT
Originally Posted by RED FURY
MSFIT ....
17% and K&N Hot Air Intake and then an OBX Header sometime this week, just waiting for it. Then sometime in the next two weeks GIAC, then I am gonna have it dyno'd at edge.
Old Mar 14, 2006 | 11:13 AM
  #37
Johan's Avatar
Johan
yup
Old Apr 15, 2006 | 02:17 AM
  #38
etalj's Avatar
etalj
ok guys, i've had my 17% pulley for two days now, and on the fway today, I redlined in 3rd gear, and my ASC light came on, and would not turn off! I thought this only happened with DSC? Did i overboost?
Old Apr 15, 2006 | 10:52 AM
  #39
MSFIT's Avatar
MSFIT
yay!!! lol...its something like overboost..thats what i get...just restart and it clears...
you can do it on the highway turn key to off and back to position 2 and it should be fine, you wont have to crank it though, engine should still be running..
Old Apr 15, 2006 | 11:31 AM
  #40
dominicminicoopers
i've heard that too high a reading on the MAP on a stock ECU can throw a DSC light on certain cars.
Mine does that. I thought it was my DSC unit getting too hot from the turbo, but I haven't been able to figure that out. So it makes sense because I get it only when I boost really hard for a period of time. :-)
Old Apr 15, 2006 | 07:39 PM
  #41
etalj's Avatar
etalj
Lol don't be happy It's not good to overboost ( Oh yes it is). MSFIT, do you have ASC or DSC?
hey dominic, is the ASC unit in the same position as the DSC unit?
Old Apr 15, 2006 | 11:01 PM
  #42
dominicminicoopers
I believe they are. The DSC unit plugs into the back of the ASC/ABS unit. The ABS unit is a square black box in the passenger side rear of the engine compartment with the metal tube lines going into it. The DSC unit is the round part connected onto the backside (outboard) of the ABS unit.
Old Apr 16, 2006 | 12:00 AM
  #43
MSFIT's Avatar
MSFIT
I have DSC
Old Apr 16, 2006 | 12:07 AM
  #44
etalj's Avatar
etalj
oh ok, i know which one now Thanks.
Is there anyone here that's thrown the ASC light (i.e. they only have ASC and not DSC?) when overboosting?
Old Feb 14, 2012 | 09:59 AM
  #45
astroBlackMetallic_Mini's Avatar
I know this is OLD, but, has anyone actually found a way around this issue? (p0108). I have recently been getting this code. It does appear if I hit over 17% psi (high as the gauge goes). The dealer has changed both pressure sensors on the car, and the IC boots, and still the error. I also have my DSC turn OFF when I hit a certain RPM, or speed. Sometimes I get one, then the other, or one, then the other, or just one, or both!
Dealer techs said to use "octane boost", bc the ethanol is messing up the air / fuel ratio. so, after finding ethanol free gas, and using octane boost, the light did NOT come on for some time... until near the end of the tank, then 10 mins from the dealer, BAM! SES light!
dealer techs say, i cant "do anything about it", bc its just how the computer is designed (along with its sensors).
So, since its NOT the sensors, and its NOT the boots, and its NOT the fuel I am using, WTF is it!
The last thing I can even try, / have not checked (not sure how), is that the CAT may be melted, or even just clogged. Others have expressed this as the cause. One NAM member put headers on his car and got that code to go away.
Thoughts!?
Old Feb 17, 2012 | 01:46 PM
  #46
El_Griton's Avatar
El_Griton
I delt with this on my old car with a 19% pulley. It continued to happen untill a had my cylinder head ported and polished and port matched it to my exhaust. This lowered the Boost pressures the computer was seeing. The pressure dropped due to the better flow. Never saw that overboost situation again. And saw some nice gains in HP and TQ.
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
