Drivetrain question about Vacuum
Old Mar 4, 2006 | 03:54 PM
Profpatpending's Avatar
Profpatpending
does the intercooler and down tubes from the intercooler experience a vacuum when the bypass is open?
I need a point to measure boost only no vacuum.
Old Mar 4, 2006 | 03:58 PM
Dr Obnxs's Avatar
Dr Obnxs
There is no such place.
When the throttle body is closed, everything past it to the cylinders is below atmospheric. Why do you need to just measure boost?
Matt
Old Mar 4, 2006 | 11:48 PM
etalj's Avatar
etalj
just get a boost gauge that only shows boost
Old Mar 5, 2006 | 02:06 AM
Profpatpending
I have it is a digital one but when the manifold is under Vacuum it puts on a warning light on the gauge as the gauge thinks there is something wrong it is only supposed to read boost.
besides how can the intercooler and charge pipes from the SC be under Vacuum if the supercharger is spinning and making boost even though the bypass is open?
Old Mar 5, 2006 | 03:11 AM
etalj's Avatar
etalj
if the bypass valve is opened, that means that any boost that's made by the charger is vented to atmosphere.
Old Mar 5, 2006 | 05:24 AM
norm03s's Avatar
norm03s
Sorry, wrong answer!
The bypass returns pressure to the intake duct between the throttle body and the supercharger while there is vacuum present on the bypass valve diaphragm.
Profpatpending, suggest you view the warning light as an economy indicator..
Old Mar 5, 2006 | 05:48 AM
etalj's Avatar
etalj
you'd think i'd know that since i've taken it apart, but i forgot....:impatient
my bad
Old Mar 5, 2006 | 07:09 AM
Bahamabart's Avatar
Bahamabart
Your gonna have to either - live w/ the red light or switch out the guage. Got a pic to share of the guage?
I'm running a VDO Boost guage which gives very entertaining needle action do to the 0-15lbs scale. I'm always afraid the needle will shoot off the face of the guage.
Old Mar 5, 2006 | 07:58 AM
Profpatpending
I sure do.
ah well.
Old Mar 5, 2006 | 08:34 AM
norm03s's Avatar
norm03s
I recommend the VDO ultra lite series -30/+30 vacuum/Boost Gauge because I believe analog gauges read more accurate mid scale rather than maxed out.
The only minor problem is that eventually the red bulb cover bleaches out and the color doesn't match anymore.
Old Mar 5, 2006 | 09:24 PM
WEEGIT's Avatar
WEEGIT
That's AutoMeter's Ultra-Lite series, and I suggest their mechanical gauge #4301 indicating boost (to 20 psi) and vacuum (to 30 in. Hg). Boost should max at about 16 psi with 15% pulley.
http://www.autometer.com/cat_gaugede...id=3149&sid=11
Old Mar 6, 2006 | 07:08 AM
Bahamabart's Avatar
Bahamabart
Actually boost with a 15 = 14.5lbs of boost.
Whats really nice about the autometers is that they match up nicely to the stock guages. I wanted max entertainment. You can not appreciate this guage until you floor it!
Old Mar 6, 2006 | 07:38 AM
norm03s's Avatar
norm03s
Duh
Now I ask myself...... WHY DID you type VDO stupid
Thanks WEEGIT, I hate spreading bad INFO around.
Old Mar 6, 2006 | 09:42 AM
ChocolateAZ's Avatar
ChocolateAZ
I used the Autometer guage and it works great, tapped in in the vacuum line going to the fuel regulator. The car is not always under boost. It is only under boost when it is under load. If I am cruising ona level highway it usually shows about 10lbs of vacuum.
Old Mar 6, 2006 | 09:47 AM
schooner2's Avatar
schooner2
Chocolate, it is not 10 pounds of vacum, it is like atmospher - mercery- something vacum. only goes in pounds when going from 0-and up, it should say something like h.a.v on one side and them pounds on the other side! JUST FYI
Old Mar 6, 2006 | 09:51 AM
Dr Obnxs's Avatar
Dr Obnxs
One inch of mercury is
0.4911541 PSI. Who knows why they use split units....
One atmosphere is 14.7 PSI at sea level, and 20 deg C, I think.
Matt
Old Mar 6, 2006 | 11:01 AM
MSFIT's Avatar
MSFIT
Get rid of that digi and get a DEFI
and for those who want a lot of action you dont need a low number boost gauge, you just need more boost :P 19%
Old Mar 6, 2006 | 11:42 AM
kapps's Avatar
kapps
Also, remember it's measuring gauge pressure so you have to add atmospheric pressure to get the actual pressure.
donniedarko
Oct 21, 2015 01:15 PM
one73ronin
23
Sep 22, 2015 09:56 AM
rob76turbo
Sep 15, 2015 10:11 AM
Sep 11, 2015 01:15 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
