Drivetrain Test Results Of Removing Pre Cat On Stock Header
Old Feb 28, 2006 | 02:44 PM
  #26
MINIotaple's Avatar
MINIotaple
I'm not too sure that it matters too much that you're using the gt-1. It might not be accurate, but the measurements before probably weren't accurate either. The deltas are what matter here. Sounds like this will be a good pairing with the webb exhaust.
Old Feb 28, 2006 | 02:48 PM
  #27
willy69's Avatar
willy69
here is a picture after i welded it back together
cheers
Attached Thumbnails Test Results Of Removing Pre Cat On Stock Header-cooper-032xx.jpg
Old Feb 28, 2006 | 02:51 PM
  #28
isellem's Avatar
isellem
ohh... okay... i was just curious... i know some dyno's have a 1/4 mile feature...
Yeah... just so as long as people don't go spouting off those numbers as actuall 1/4 mile times... im good with it...
i think its great for comparison for mods and thing like that though... when you are comparing it to your car and only your car... i think you have a good idea
Old Feb 28, 2006 | 02:55 PM
  #29
willy69's Avatar
willy69
if i can get to your numbers at the strip, i will be real happy
cheers
Old Feb 28, 2006 | 02:56 PM
  #30
isellem's Avatar
isellem
cheers
HELL YA! THAT WOULD BE COOl!
Old Feb 28, 2006 | 04:47 PM
  #31
Dr Obnxs's Avatar
Dr Obnxs
Accelerometers can be very accurate..
Especially on time to distance. Things that will screw up the numbers are any staging settings that can go into them, and pitch (the amount the car leans while accelerating). The HP numbers are a bit more suspect, as they are calculated based on measured acceleration, and the vehicle mass.
There was an article in one of the car mags where they were getting the G-Tech to agree to the 1/4 mile times within a tenth.
Oh yeah, the other screw up source is altitude changes where you run. Slight downhill=more HP!
But the best thing is that you get real world airflow with these suckers. No more worrying that the fans are too big or too small.
And yes, the deltas are what's most important.
Matt
Old Feb 28, 2006 | 04:54 PM
  #32
Detonics's Avatar
Detonics
I thought we should cut the section below and weld it back with a pipe. You can see that the pipe size is smaller at the sensor hole area.. and i think that area should be removed and replaced.
Attached Thumbnails Test Results Of Removing Pre Cat On Stock Header-cooper-20032xxx.jpg
Old Feb 28, 2006 | 08:00 PM
  #33
willy69's Avatar
willy69
yes, i agree with that, what i am doing is one thing at a time to find what works and what does'nt work. i hope i can find another stock header to to make a straight piece to replace the whole run between the flex joint and the main cat, then test it against this one. this header looks 100% stock, i would like to see the smog police find that this stock header has been tampered with,it would take a x-ray to find that it has been altered. this thing fits perfect, basicly the same sound level, and makes better power. i will post pics and results when i do the next one.
cheers
Old Feb 28, 2006 | 09:28 PM
  #34
MINIotaple's Avatar
MINIotaple
Make sure to take good pictures and remember what you do because I'm probably going to want to copy you. It doesn't help that I can't visually tell the difference between the original header and your modified one.
Old Feb 28, 2006 | 09:31 PM
  #35
Dr Obnxs's Avatar
Dr Obnxs
Isn't that the point?
This round is the totally stealth, undetectable by inspection, low cost exhaust mod!
The little doo-hicky is gutted! To use the technical term....
Matt
Old Feb 28, 2006 | 09:35 PM
  #36
MINIotaple's Avatar
MINIotaple
Matt
Okay, I just thought that it was undetectable by state inspectors. I mean what do they know about Mini parts? The manifold being gutted makes sense now.
Old Mar 1, 2006 | 03:41 AM
  #37
Detonics's Avatar
Detonics
So, let's wait for the PART2 by *****! Cheers to you mate!
Old Mar 1, 2006 | 07:37 AM
  #38
Bahamabart's Avatar
Bahamabart
i started with a gt-1 made by passport, basicly a gtech copy. i will be the first to say the actual numbers may not be correct, but the differences in the numbers i believe to be true. i have not changed any parameters in the box since i started this test. the first time i had before any of the mods i have done was 14.65@96.7mph, this is with a 15% pully, cai, 2.5 dia exhaust. the best time i have had since adding the mods is13.50@108mph , i am running consistantly in the 13's according to the box. again not sure how accurate the box is. i will post the mods and increases i have seen from the beginning. as far as the header mod goes, i saw about a 4hp-6hp gain with out changing the ecu file, i am still waiting for the new file from mth. as far as the sound it may be alittle deeper but i don't notice it too be any louder.
cheers
How are you measuring this 4-6hp gain?
Old Mar 1, 2006 | 07:54 AM
  #39
Dr Obnxs's Avatar
Dr Obnxs
Google and ye shall find!
http://www.cardomain.com/item/ESCGT1
Matt
Old Mar 1, 2006 | 09:27 AM
  #40
Bahamabart's Avatar
Bahamabart
I didn't think the escort measured HP but I see that it does.
Old Mar 1, 2006 | 09:29 AM
  #41
Dr Obnxs's Avatar
Dr Obnxs
Once you have acceleration....
All you need is mass to do power. And RPM to do power vs RPM. It's just math.....
Matt
Old Mar 1, 2006 | 11:51 AM
  #42
Bahamabart's Avatar
Bahamabart
Matt
maybe from where you come from - here in the Bahamas, we need more
Would love to somehow compare to a header - to determne which is a better bang for the buck - this mod or an OBX header (as an example).
Old Mar 1, 2006 | 07:18 PM
  #43
TonyB's Avatar
TonyB
Slightly OT... I found a guy parting-out a Cooper about 45 minutes south of me. Are the headers the same (as compared to an S)? Thanks much.
Old Mar 1, 2006 | 07:20 PM
  #44
Dr Obnxs's Avatar
Dr Obnxs
yep
same part. good score!
Matt
Old Mar 1, 2006 | 07:51 PM
  #45
TonyB's Avatar
TonyB
Matt, thanks for the quick confirm. Are you 100% sure, even the cat is the same? I'm going to check the Bentley manual now also....
Old Mar 1, 2006 | 07:59 PM
  #46
Dr Obnxs's Avatar
Dr Obnxs
Yep
Just checked realoem.com
up to 2/03 both used 1840750281
up to 9/03 both used 1840755274
No information on what was different between the two, but they both used the same number for the same times. Looks like the part was upgraded (who knows why, maybe it worked too good! ) but at the same time for both cars.... I didn't check all years and the like,
Matt
Old Mar 1, 2006 | 08:07 PM
  #47
TonyB's Avatar
TonyB
Very interesting Matt. This guy says that his is an 02, so finding-out the difference would be nice to know. Looks like I'll need to do some research tonight
Old Mar 1, 2006 | 08:08 PM
  #48
Dr Obnxs's Avatar
Dr Obnxs
There's no difference in the photos...
I'd guess that dimensionally they're the same, as the other parts (like gaskets etc) didn't change...
Probably the parts that you're planning to gut are what's different....
Matt
Did you do your Unichip tune yet?
Old Mar 1, 2006 | 08:10 PM
  #49
MINIotaple's Avatar
MINIotaple
I just looked at realoem.com and the part used after 9/03 is 18407533402. Is there a difference between the earlier ones listed and the later ones?
Old Mar 1, 2006 | 08:22 PM
  #50
Dr Obnxs's Avatar
Dr Obnxs
I really couldn't tell...
But I didn't look at all years, and see if the gaskets changed, or if the cat back system did. But for the two parts I did look at, the head gasket was the same.....
