Drivetrain G-Tech Repeatability
Old Feb 21, 2006 | 05:14 PM
Dr Obnxs's Avatar
Dr Obnxs
Hi all,
I thought I'd post this for those that are curious how repeatable the G-Tech can be. These are some runs I did for IC testing....
Also, these were power runs, so I shift early, and the 0-60 times suck. But they overlap nicely.
Matt
Old Feb 22, 2006 | 04:57 AM
Koopah's Avatar
Koopah
Matt,
Any suggestions for calibrating the GTech for the MCS other than what the manual says? I've got a JCW MCS with stock suspension except for the rear bar.
I bought Garretwp's (Competition model) and would be interested in any additional info you have found to increase repeatability.
Thanks,
Theo
Old Feb 22, 2006 | 07:46 AM
Dr Obnxs's Avatar
Dr Obnxs
Get your car weighed...
I thought mine would come in at 2800 lbs, and I'm about 230 plus a bit.... But when I got my car corner balanced, it's closer to 2600. I've kept the heavy weight in the G-Tech because I'm in the middle of a series of tests.....
For good repeatability, testing procedure has more to do with it than anything else. I run on a freeway onramp. After I do a run, I circle around using the cruise control to keep speeds constant. After I stage again, I try to launch quickly, so heat soak doens't effect the reading. With the stock IC, I can have post IC temps down around 20 C (on a 16 C day) when I stage, and I try to launch before they get much over 25. If I sit and screw with all the data collection stuff for too long, or there's a bunch of traffic, the temps rise rapidly, and it will show in slightly reduced power numbers. So repeatable testing proceedures will get you repeatable numbers...
Matt
Old Feb 22, 2006 | 09:48 AM
Koopah's Avatar
Koopah
Time to go to the recycling center and borrow their weighting platform!
BTW - do you use the standard 2.0 pitch setting or have you taken that down a bit due the the MCS's stiff suspension?
Theo
Old Feb 22, 2006 | 11:26 AM
Dr Obnxs's Avatar
Dr Obnxs
2.0 for pitch...
Never changed it. I don't know if you need to, unless you're trying to get the numbers to match a drag strip. Also, while the car is stiffer, it sure is shorter as well! Who knows what should go here.
I've been crunching some numbers....
6 HP runs have a standard deviation of 2.4 HP
6 Torque runs (same ones) have a StDev of 2.7 ft-lbs
Same 6 runs have a st dev on 40-60 times of 0.05 seconds....
all are 1%-2% of average value. Works pretty well!
Matt
Old Feb 22, 2006 | 12:14 PM
Koopah's Avatar
Koopah
Thanks, Matt!
Theo
Old Feb 27, 2006 | 08:37 PM
matma92ser's Avatar
matma92ser
Dr. Obnxs - where is this on ramp? I have an older G-Tech but I never have a chance to use it because it's difficult to find a good testing area: one that is free from traffic and police.
Old Feb 27, 2006 | 09:02 PM
Dr Obnxs's Avatar
Dr Obnxs
Down 280..
South bay, peninsula, right near stanford university.
Matt
Old Feb 28, 2006 | 07:55 AM
Bahamabart's Avatar
Bahamabart
very cool.
I've had some pretty big swings - I need to go back and control my testing enviroment more!
Old Feb 28, 2006 | 04:37 PM
Dr Obnxs's Avatar
Dr Obnxs
To get the most repeatability...
Originally Posted by Bahamabart
very cool.
Create a routine to condition the car. I use about a 6-7 mile loop to the next exit, set the cruise control at the same speed, and try to sit in staging for a short as possible a time before launching.
If the IATs are within about 5 C, you get the best repeatability...
Matt
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
Eurothrasher
Sep 9, 2015 12:00 PM
