Drivetrain 27PSI plus 100 Octane...
Old Feb 20, 2006 | 10:55 PM
spillman's Avatar
spillman
Just another dyno chart to show how big of a horsepower junky I am. This was a the SPI stage 2 kit with a 15% pulley (27psi total). I made a lot of torque and almost as much horsepower. Check out that torque curve. Needless to say the car has trouble hooking up in 3rd. Next week the a different superchager pulley goes on.
Old Feb 20, 2006 | 10:58 PM
Tüls's Avatar
Tüls
Turbius Maximus
AWSOME STUFF RYAN!!! I'll tell you what...if you are going to stock pulley, I'll put $ down that you are going to hit the 290s...and prolly on less boost...
Old Feb 20, 2006 | 11:03 PM
spillman's Avatar
spillman
I plan on being a good bit over 290. I am doing my fuel system this week and I will hopefully source a pulley by next week. My goal right now is 350whp.
Old Feb 20, 2006 | 11:32 PM
Tüls's Avatar
Tüls
Turbius Maximus
damn right!!! LOL....sounds about right...he who shal not be named....is up around 375 now...somethign like that...reeeeediculous! you still gunnah spray? LOL...that should get you 450! heh ehh
Old Feb 20, 2006 | 11:35 PM
Dr Obnxs's Avatar
Dr Obnxs
Now you're doing...
what my 5.0 NA EFI motor is pushing! 3x the power density, but at probably 3x the price.....
V8s are cheap!
Really impressive numbers. What's your tire life like?
Matt
Old Feb 21, 2006 | 03:50 AM
dominicminicoopers's Avatar
dominicminicoopers
Ryan,
What clutch are you running to keep up with your ~300ft-lbs of torque?
Old Feb 21, 2006 | 07:18 AM
spillman's Avatar
spillman
I am using the Spec Stage 3 clutch and Spec flywheel. They don't have trouble holding the torque in any gear.
Old Feb 21, 2006 | 07:22 AM
dominicminicoopers
Awesome! :-) How many miles do you think you'll be able to get out of it?
spillman's Avatar
spillman
V8s are cheap!
Matt
Yes I pulled up beside a 5 slow last night. Needless to say I pulled a disapearing act on the guy. V8s are cheap but heavy.
Also my tires are taking a beating even on low boost (22psi). It started raining last night and I ended spinning 4th gear pulling on the highway.
Old Feb 21, 2006 | 07:24 AM
spillman's Avatar
spillman
I currently have about 15,000 miles on the clutch. Still grabs as good a as new. I do baby the clutch on a daily basis. But under certain conditions I flat shift the car and do slip clutch launches at 4,000.
Old Feb 21, 2006 | 07:25 AM
Ryephile's Avatar
Ryephile
Why does your torque drop off so sharply at higher RPM? Are you reducing boost as RPM rises?
Old Feb 21, 2006 | 07:27 AM
dominicminicoopers
Nice!
Old Feb 21, 2006 | 07:29 AM
supe2000's Avatar
supe2000
Spillman, you're my hero. I think the MINI I have on Gran Turismo 4 has around 320 hp, that's probably as close as I'll ever get.
Old Feb 21, 2006 | 07:42 AM
spillman's Avatar
spillman
Yes boost is cut back sharply. Remember now that the supercharger puts out more boost at higher rpms. I am making max boost from the turbo around 3-4 grand and then it cuts back to maintain 27psi.
Old Feb 21, 2006 | 09:57 PM
Ryephile's Avatar
Ryephile
I'm guessing the major drop in torque is then due to the reduced compressor efficiency [going from mostly turbo boost to mostly s/c boost], if you're indeed running 27psig across the board.
Old Feb 22, 2006 | 10:32 PM
spillman's Avatar
spillman
Exactly... And that is why I should pick up a good bit of power from swapping the pullies.
Old Feb 22, 2006 | 10:57 PM
Tüls's Avatar
Tüls
Turbius Maximus
and that's a crank HP rating...which means spillman's crank is 313 hp LOL
....and mine is 340 hp LOL stuuupid...LOL
and I am sure mr spillman will surpass that as soon as he get's that puley squared away...
Old Feb 23, 2006 | 02:23 AM
mybroscoop's Avatar
mybroscoop
Are you going to a stock sice pulley or a larger diameter?
Old Feb 23, 2006 | 05:30 AM
Hounddog's Avatar
Hounddog
Spillman,
Great numbers. I see you've upgraded the clutch but what have you done internally to the motor to handle the new numbers and future numbers....
Old Feb 23, 2006 | 08:01 AM
spillman's Avatar
spillman
I am going to try a larger diameter first. And then see what the stock pulley does.
Internally I have CP pistons ARP head studs and rod bolts. Everything else is stock.
Who knows... Maybe next week I will fill the tank up with C16 and see what happens.
Old Feb 23, 2006 | 10:00 AM
Tüls's Avatar
Tüls
Turbius Maximus
dooo it!!
ian260
Mar 29, 2017 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
gnhovis
Sep 28, 2015 04:07 AM
