Drivetrain Aftermarket Resonator?
Old Jan 24, 2006 | 11:57 AM
Stricks's Avatar
Stricks
Can any one recommend, or at least suggest, some aftermarket resonators? I'm doing a custom exhaust, and would like to be prepared in case there's too much noise or drone.
BTW, I know about the Supersprint resonator/straight pipe, but it costs way too much and really all I want is the resonator.
Thanks!
Old Jan 24, 2006 | 12:32 PM
Minirowski's Avatar
Minirowski
MagnaFlow you can use.
Scuderiamini build his cutom exhaust.
https://www.northamericanmotoring.co...t=scuderiamini
There you go.
Old Jan 24, 2006 | 12:35 PM
Bahamabart's Avatar
Bahamabart
they got them on Ebay - really cheap.
Old Jan 24, 2006 | 12:38 PM
Stricks's Avatar
Stricks
There you go.
Thanks for the link.
As far as I know, Berk's (ScuderiaMini) exhaust doesn't have a resonator, just the Magnaflow muffler. I'm looking for a resonator to put in the straight pipe that will reduce the noise of the custom exhaust I'm going to build (which, incidentally, is very similiar to Berk's).
fishbulb's Avatar
fishbulb
I used a SS magnaflow on my turbo miata. Really helped cut down on the noise at slow speeds/idle (around the neighborhood) but it didn't choke the power or sound when i wound it out....
bought it from summit, i think it was a 12" long case, 16" overall. Maybe in the $60-70 range?
-jac
Old Jan 24, 2006 | 12:41 PM
Stricks's Avatar
Stricks
Thanks for the suggestion -- should I just look for something with the same inlet/outlet diameter as the straight pipe I'm going to use? Any other characteristics I should look for?
Old Jan 24, 2006 | 12:45 PM
Stricks's Avatar
Stricks
-jac
Was it a shaped like a tube (fittable into a straight pipe), or more like a standard muffler?
Old Jan 24, 2006 | 12:46 PM
Minirowski's Avatar
Minirowski
Off topic but what kind a exhaust design you gonna go with? Alta style?
Old Jan 24, 2006 | 01:07 PM
Stricks's Avatar
Stricks
The Alta design is pretty similiar to what I want to do. Mine won't be as pretty, since I'm budget minded, but close. Just think of it as a single sided Magnaflow, with a different tip.
Old Jan 24, 2006 | 02:19 PM
Stricks's Avatar
Stricks
So, any other suggestions on manufacturers or sellers? ebay seems to have some inexpensive possibilities...
Also, does anyone know how (or if) the length of the resonator affects the sound reduction?
Old Jan 24, 2006 | 02:35 PM
Bahamabart's Avatar
Bahamabart
Yes - they offer a variety of inlet/outlet dimensiones. search universal resonator. example -
http://cgi.ebay.com/ebaymotors/2-5-U...31571850QQrdZ1
Read carefully sometimes the offer is for 1 and other times for 2.
Old Jan 24, 2006 | 07:49 PM
fishbulb's Avatar
fishbulb
tube shaped - looks very much like the one bart shows above.
JHolland
Sep 24, 2020 08:20 AM
knbond1
Sep 4, 2016 02:30 PM
vulkandino
Oct 31, 2015 08:29 PM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
