Drivetrain Stock Header With No Pre Cat?
Old Feb 25, 2006 | 07:07 PM
  #76
Detonics's Avatar
Detonics
Yeah, I've read the thread last year.. but was unable to get clear picture on how to do it, I roughly know how to do it.
*****, make sure you take some pictures of the header after the mod before you fit it back to the car...
Old Mar 4, 2008 | 06:57 PM
  #77
k-huevo's Avatar
k-huevo
Two years later...
Here’s the follow-up thread for willy69 https://www.northamericanmotoring.co...ad.php?t=62142 .
My pre-cat delete version modified at Corky Bell’s shop.
The pre-cat has a narrow opening (less than 2 in. ID); keep in mind only one gas pulse at a time passes through here so that’s not so bad, and the stock head and SC pulley don’t provide much for port velocity, so any thing to help speed things along like this swage shape, is a good thing.
However, the cat core is tightly spun which may cause some restriction when VE is improved upon. The aftermarket cat on the left is 300 cell; the OEM pre-cat appears to be much denser.
In addition to replacing the pre-cat with open tube, the flange ports were enlarged to match my ported head, an additional O2 ring installed, the wire feed weld bead at the exit was ground down (almost .25 inch ID gained), weld blobs were removed at the flex joint, and the primaries were ceramic coated.
To handle the increased noise, a 5 inch diameter Magnaflow muffler is attached to my one-ball exhaust.
Old Mar 5, 2008 | 07:28 AM
  #78
Bahamabart's Avatar
Bahamabart
nicely done.
Old Mar 5, 2008 | 07:49 AM
  #79
newbs49's Avatar
newbs49
Very nice job for people who don't want to spend extra $$$$$ on a new header.
Old Mar 5, 2008 | 08:14 AM
  #80
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by k-huevo
This is exactly what my stock header looks like. Nice job Keith, and thanks for the post.
Old Mar 5, 2008 | 09:43 AM
  #81
Dr Obnxs's Avatar
Dr Obnxs
Nice Keith...
wouldn't expect anything less. Next thing you know though, you'll be running longer primaries and you have...
a header again!!!!!
Matt
Old Mar 5, 2008 | 09:48 AM
  #82
Bahamabart's Avatar
Bahamabart
a header again!!!!!
Matt
Thats funny because I was thinking the same thing - cut slightly higher, extend pipes, ect......................................
Old Mar 5, 2008 | 11:16 AM
  #83
70spop's Avatar
70spop
Pretty spiffy. I knew there was a reason I kept the pieces of my stocker (one of the seams on the pre-cat split - the parts are in two pieces).
Old Mar 5, 2008 | 11:28 AM
  #84
the platform's Avatar
the platform
nice fabrication
Old Apr 24, 2011 | 02:50 PM
  #85
R53 Speed's Avatar
R53 Speed
I bought a stock header from a local guy who had already gutted the pre-cat and the cat. Probably gonna put my cat on it though so it doesn't sound so raspy and loud. However, the guy also went to the trouble of porting it out for more flow.
Cost me $60
PhoR53
Aug 21, 2015 05:10 PM
Aug 21, 2015 10:36 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 01:59 PM
