Drivetrain Stock pistons?
Old Apr 22, 2011 | 04:48 PM
La Pulga's Avatar
La Pulga
Stock pistons?
I'm Thinking About Getting A Mini-madness Stage 1 Head, Putting In New Oversize Valves 1.8mm Intake Valves And 2.3mm Exhaust Valves And Throwing In A Schrick Cam As Well. Question Is Would I Run Into Any Problems If I Use Stock Pistons With This Upgrade?
Old Apr 22, 2011 | 05:40 PM
Vollgas's Avatar
Vollgas
Your stock pistons should work fine.
The R53 pistons are designed to deal with the extra heat from a SC.
You are only increasing the air volume, not any extra heat.
Your compression ratio, 8.3:1, should not change much at all.
Old Apr 24, 2011 | 09:18 AM
La Pulga's Avatar
La Pulga
I Sure Hope So Vollgas! Thanx For Replying!
Old Apr 24, 2011 | 10:31 AM
MINI33342's Avatar
MINI33342
You really ought to check out the Thumper heads. They are a much better product than the Madness ones.
Old Apr 24, 2011 | 11:46 AM
firenewt's Avatar
firenewt
+1
Kevin
Old Apr 25, 2011 | 08:23 AM
La Pulga's Avatar
La Pulga
man i wished u would've told me that earlier. i already send my head to get worked on by mini-madness
Colt45Magnus
Aug 27, 2024 05:03 AM
USA-RET
Nov 9, 2015 07:27 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
squawSkiBum
Sep 2, 2015 09:56 PM
