Drivetrain 2005 EOY, pulley problem audit
Old Nov 30, 2005 | 04:44 AM
Wagnbat's Avatar
Wagnbat
Aftermarket Pulley problems as of the End of Year 2005.
If you'd be kind enough to share, I'd like to tally up some numbers, which I intend to update here at the top, for people who have and have not had problems with 15-19%+ pullies from any company or installer, excluding JCW pullies.
Looking for 'no' problems answers, with # of months installed, and yes answers with # of months before first issue. Please keep issues brief, and related to 'actual' issues caused by the pulley, and not 'well the dealer said my alternator died because the pulley was drawing too much power' and similar false associations.
The format I plan to keep is a simple table of # of yes's and no's, with min/avg/max of each for months.
Please also post reduction %'s, as that may come into play later, but I do not believe company name or installer is necessary. Thanks
Aftermarket Pulley problems?
Nope!
34 people
Months (min/avg/max): 3 / 11.6 / 34
YES
0 people
Months: 0 / 0 / 0
Last tally taken 12/2 1:13pm
* REMINDER * Not tabulating submissions from people whom do not include # of months installed.
Old Nov 30, 2005 | 05:04 AM
aokdoug's Avatar
aokdoug
nope 19% 22 months
Old Nov 30, 2005 | 05:05 AM
GoodOlDan's Avatar
GoodOlDan
15% Alta pulley, installed 18 months, no problems
Old Nov 30, 2005 | 05:08 AM
spirit16's Avatar
spirit16
Alta 15% pulley
12 months (installed November, 2004)
8,000 miles
no problems at all.
PS-I see that you are only requesting time, but should mileage factor also be considered ??? just my two cents.
Old Nov 30, 2005 | 05:27 AM
Petey's Avatar
Petey
no problems
19% 3 months/5k
Old Nov 30, 2005 | 05:29 AM
DrkSilvrMini's Avatar
DrkSilvrMini
5 months, and other then throwing a belt not one problem
Old Nov 30, 2005 | 05:33 AM
RED FURY's Avatar
RED FURY
15 %, 1 year, no problems
Old Nov 30, 2005 | 05:35 AM
minimort's Avatar
minimort
19%, installed for 15 months (approx. 30kmiles), no problems. On my 3rd belt, but that's just due to replacing after occasional squeaking
Old Nov 30, 2005 | 05:36 AM
mdsbrain's Avatar
mdsbrain
NO, 15% 4months 6k miles since install. Installed In July by Randy Webb.
NO, 0% Lightweight crank. 2 months and 2500 miles. Installed in Oct by Randy.
Old Nov 30, 2005 | 05:50 AM
paulsminis's Avatar
paulsminis
No problems, only joy/15% Alta pulley by Randy Webb, 2+ years, 20K miles
Old Nov 30, 2005 | 06:11 AM
F15EWeapon's Avatar
F15EWeapon
15% Alta Pulley/20 months/15,000 miles
2% Alta Crank Pulley/2 months/3,000 miles
ZERO troubles or issues
Old Nov 30, 2005 | 06:13 AM
MightyMini's Avatar
MightyMini
No Problems, 15% Alta pulley, 6 months, about 6,000 miles
Old Nov 30, 2005 | 06:29 AM
inimmini's Avatar
inimmini
No probs, 15%, 6 months, 7K mi
Old Nov 30, 2005 | 07:48 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
15% MINI-Madness pulley, for 22 months now, and at least 75000km driven on it!
I changed my belt once last year, and no problem with the pulley or belt!
(or anything else related to this mod! )
Old Nov 30, 2005 | 07:56 AM
hornguys's Avatar
hornguys
18,000 miles on 15% - no problem.
Then, 30,000 miles on 19% - no problem, but changed the belt every 10,000 miles as a precaution.
Then, 14,000 miles on 16% with 3% crank pulley. No problems after initial belt alignment issue.
Can't imagine having at least a 15% pulley!
Old Nov 30, 2005 | 07:57 AM
Bahamabart's Avatar
Bahamabart
no problem
RDR 15% pulley
6 months
Old Nov 30, 2005 | 08:00 AM
Wagnbat's Avatar
Wagnbat
Can't imagine not having at least a 15% pulley!
Can't put into my database without # of months, and wether or not you consider those issues problems or non-problems. I'd assume the belt changes and alignment don't count as problems, as they were not *caused* by the pulley... But I'd rather not assume, so I'll just tabulate the data.
Old Nov 30, 2005 | 08:02 AM
Larry Clemens's Avatar
Larry Clemens
15% Alta - no problems at 10 months
Old Nov 30, 2005 | 08:04 AM
MINI Monkey's Avatar
MINI Monkey
Webb installed 15% pulley on for 13 months-----No Problems.
Old Nov 30, 2005 | 08:24 AM
SRTech's Avatar
SRTech
Alta 15%, 3 months, 10,000 miles, no problems.
Steve
Old Nov 30, 2005 | 09:42 AM
protoculture's Avatar
protoculture
Helix 15%, 3 mos., 1k miles, no problems.
Old Nov 30, 2005 | 09:47 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Alta 15% Redux Pulley 5 months
Alta 2% over driven lightweight crank pulley 1.5 months
Randy webb installed both. No problems
Old Nov 30, 2005 | 09:52 AM
10851CS's Avatar
10851CS
Alta 15% by Randy Webb at AMVIV Feb 04 = 22 months
NO PROBLEM (stock belt)
Earl
Old Nov 30, 2005 | 10:55 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
15% then 19%
34 months
no probs
Old Nov 30, 2005 | 11:37 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Nope. 15% Alta. Installed Nov 2003 (24 months)
