Drivetrain Cam troubles
Old Nov 29, 2005 | 09:51 AM
minimort's Avatar
minimort
Cam troubles
I have a cam question. Are there any out there that don't involve trimming the spark plug housings? I know the Ultrik requires this, but does the Schrick too? Are there any others available?
Would be for an S
Old Nov 29, 2005 | 12:34 PM
M7's Avatar
M7
Hi this is a very well known issue, and very easy to fix.
Take a small hammer, tap lightly on the tubes where the cam lobe hits
untill the cam clears. Don't over do it as the sparkplugs will get stuck.
Good luck
peter
Team M7
562-608-8123
Old Dec 1, 2005 | 05:10 PM
motorsports3's Avatar
motorsports3
To prevent overdoing it, put your spark plug socket in the tube while hammering it. That way you get enough clearance and know for sure that you can still get the plugs in and out.
Old Dec 2, 2005 | 09:51 AM
isellem's Avatar
isellem
Ultrik just copied the schrick cam... look at the cam specs on their website they are exactly the same... But Ultrik claims that you don't have to use the upgraded valve train with their cam... but you have to with the schrick... which we all know is a lie...
anyways... back on topic...
just put your sprark plug wrench in the tube and bang the spark plug tubes until their is suffiecent clearance for the tool and the cam
its really not to hard let us know if you have problems
navybsn
Oct 5, 2018 04:42 PM
navybsn
Oct 4, 2015 03:27 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
WhinyR53
Sep 30, 2015 07:36 AM
