Drivetrain Custom Exhaust?
Old Nov 21, 2005 | 01:07 PM
motorsports_3's Avatar
motorsports_3
Custom Exhaust?
My local muffler shop could build me a custom exhaust for around 300.00 dollars. It will be mandrel bent with a magna flow or borla muffler, using one muffler. What do you guys think of this. Or should i save up a bit more and get a borla race? Also what size piping should i use, and should i keep the stock cat? Thanks
Sami
Old Nov 21, 2005 | 01:14 PM
norm03s's Avatar
norm03s
Save your money for a mandrel bent stainless steel system.
You will only get maybe 5 years out of it and it may not be as good as the stock system.
I bought a used Magnaflow for that kind of money.
Old Nov 21, 2005 | 01:27 PM
MSFITOY's Avatar
MSFITOY
Two of my Mini friends have custom system built up for their Mini and resulted in two unique looks and sound. One used a single large Borla muffler and the other used an unknown CF flow through muffler. Both have a large single large exhaust. I had my Borla race modified as well by replacing the main pipe with 2.5" SS, exchanged front resonator and custom exhaust tips. All three of us used the same shop that routinely builds custom headers/exhaust systems for race cars. Conclusion? Building a custom exhaust system is not difficult as long as you use a reputable shop that has quality experience building exhausts for performance cars. Stay away from Midas type places. Asides from saving money, we also ended up with one of a kind, quality built systems than sounds unlike anyone else's off the shelf set:smile: Check out the sound clips below my sig. The actual note is lower than recorded. Very different from a stock Borla Race
Originally Posted by motorsports_3
My local muffler shop could build me a custom exhaust for around 300.00 dollars. It will be mandrel bent with a magna flow or borla muffler. What do you guys think of this. Or should i save up a bit more and get a borla race? Also what size piping should i use, and should i keep the stock cat? Thanks
Sami
JeffS's Avatar
JeffS
I didn't hear him say that it wasn't going to be stainless.
Anyway, a one muffler system is going to be QUITE loud. If that's what you want, then go for it. As far as size, I would go at least 2.5".
Old Nov 21, 2005 | 01:32 PM
Bahamabart's Avatar
Bahamabart
The only problem with building your own - is that you don't know what you will end up with. There is a science to this! Beter off going with something that is tried and tested.
you can buy a OBX exhaust on ebay for 299.00
I'm running it - summary
its on the louder side,
not a true cat back,
stainless steel,
nicely made and hangs nicely.
Old Nov 21, 2005 | 01:36 PM
MSFITOY's Avatar
MSFITOY
None of us are using muffler only. A front resonator is necessary. If you don't have any experience with exhaust systems, then I wouldn't waste the time playing around. We knew pretty much what plus what would end up with what we wanted:smile:
stainless steel,
Old Nov 21, 2005 | 02:26 PM
Samurai Will's Avatar
Samurai Will
I built one using no mufflers, and it isn't that loud.
http://www.teammightyminiz.com/users/will/driveby.MPG
Of course, I used some secret ingredients, but the sound is most excellent.
BRracing
Dec 22, 2015 09:25 AM
yukinoinu
Sep 20, 2015 09:10 PM
honderpilot
Aug 31, 2015 02:53 AM
JPMontes3
Aug 24, 2015 07:15 AM
jrezzo
Aug 9, 2015 10:32 PM
