Drivetrain Increasing SC effiency. Different methods?
Old Nov 13, 2005 | 09:40 AM
  #26
J0kER's Avatar
J0kER
this could be far fetched but......
so is there a better blower option out there (direct replacement) mayb
Old Nov 13, 2005 | 01:18 PM
  #27
jlm's Avatar
jlm
from google search on Eaton roots supercharger
"... most positive displacement schemes compress the air simply by shoving it into the intake manifold. As a chamber of not-yet-pressurized air is opened to a manifold of already-pressurized air, air first rushes from the manifold into the chamber, before being shoved back out into the manifold. Thus, much of the air is pumped twice, and it goes past the edges of the supercharger exit three times. The resulting turbulence heats the air, reducing compressor efficiency. As one might suspect, streamlining of compressor inlets and outlets becomes very important."
Old Nov 13, 2005 | 01:41 PM
  #28
ingsoc's Avatar
ingsoc
JLM, AWESOME quote....thanks :smile:. So, it is correct to think that opening up/reducing resistance to flow out should be pursued too, right? I love my M7 blower and believe that it's quite the piece, simply because it opens up the output side. It actually SOUNDS like it breathes easier when spooling. I remember noting that the first time I drove with it... it sounded breathless and _smooth_. It's hard to quantify that... but just wait til you hear a ported blower, it sounds sweet :smile:!
Old Nov 13, 2005 | 02:04 PM
  #29
MSFITOY's Avatar
MSFITOY
I don't know anything but I bet on M7 to come up something different/better
Old Nov 13, 2005 | 03:35 PM
  #30
macncheese's Avatar
macncheese
My interpretation is that the text below agrees with what I suggested above about the triangle's intent is to seal the outlet so that only one volume of air is passing through at a time. The way the other blower is ported is allowing compressed air to escape back into the volume in queue, as the blower's edge is no longer sealing that volume from the intake manifold.
Old Nov 13, 2005 | 03:44 PM
  #31
jlm's Avatar
jlm
at the risk of chewing cabbage twice...a too large output can re-circulate already pressurized manifold air; not a good thing. the little triangular holes do the same thing.
Old Nov 13, 2005 | 03:50 PM
  #32
SpiderX's Avatar
SpiderX
so....bottom line do these mods work or not? if so what are the gains? please
Old Nov 13, 2005 | 04:05 PM
  #33
k-huevo's Avatar
k-huevo
Speaking of the little side openings. How in the world do they allow for quieter operation? It seems a little counter intuitive to me.
If an aural sensation is indicative of the SC doing its job; the Endyn version has certainly clocked in for the day.
Old Nov 13, 2005 | 04:43 PM
  #34
macncheese's Avatar
macncheese
The little side ports allow some pressure to leak backwards into the volume of air up next to push through the triangular discharge port. The pre pressurized air then gets pumped through the triangle at a pressure thats closer to the manifold pressure vs the big pressure difference a well sealed, well timed blower with the ports sealed off can see.
The slots alllow a gentler (quieter) transition at the expense of doing work twice.
Old Nov 13, 2005 | 04:58 PM
  #35
J0kER's Avatar
J0kER
g00d! it's about time!!
=0)
Old Nov 13, 2005 | 05:41 PM
  #36
jlm's Avatar
jlm
reading material:
http://www.capa.com.au/library_vortech_testing.htm
Old Nov 13, 2005 | 05:55 PM
  #37
J0kER's Avatar
J0kER
Old Nov 13, 2005 | 08:31 PM
  #38
ingsoc's Avatar
ingsoc
I do too .
Old Nov 14, 2005 | 08:57 PM
  #39
J Propane's Avatar
J Propane
Originally Posted by autoxguy305
Do you need the S connecting rods? I could supply a good block with just an S crank.
You have PM!
Old Nov 14, 2005 | 09:33 PM
  #40
autoxguy305's Avatar
autoxguy305
Originally Posted by J Propane
You have PM!
havn't gotten anything...
Old Nov 14, 2005 | 09:56 PM
  #41
J0kER's Avatar
J0kER
wuz ur box full mayb....
Old Nov 15, 2005 | 04:44 AM
  #42
J Propane's Avatar
J Propane
Re-sent but still in my "sent-items" list!
Old Nov 15, 2005 | 09:24 AM
  #43
jlm's Avatar
jlm
found this bit on mini2: one user got 19psi with the stock blower but boost dropped to 13.4 with the M7; put the stock back on and 19psi again 19% pullies all cases.) Now before you get twisted, there is the argument that it is the amount of O2 that matters, not the psi, although they mey be related, depending on temp. my rig has seen 19% with the Endyn blower, but I do have high IAT.
http://www.mini2.com/forum/showthrea...=102066&page=3
Old Nov 15, 2005 | 09:45 PM
  #44
autoxguy305
i've been doing a little more research, and i've seen a few pictures of factory m45 and m62 supercharger with an outlet port very similar to the M7 setup. Maybe thats where they got the idea? I'll try to find some good pictures.
Old Nov 15, 2005 | 11:55 PM
  #45
J0kER's Avatar
J0kER
)=o)
i've been doing a little more research, and i've seen a few pictures of factory m45 and m62 supercharger with an outlet port very similar to the M7 setup..
where did u spot this?
Old Nov 23, 2005 | 10:42 PM
  #46
Dr Obnxs's Avatar
Dr Obnxs
Cruising around and found this....
deltas for a ported SC on a Ford V8...
http://www.modularfords.com/forums/2...=Ported+Blower
FWIW
Matt
NYMADMINI
Dec 14, 2016 02:33 PM
bahman
Feb 14, 2016 10:29 AM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
