Drivetrain Cat removal
Old Nov 4, 2005 | 12:45 AM
Profpatpending's Avatar
Profpatpending
Cat removal
what sort of gains are to be had from removing the cat?
I know about the implications but it is just curiosity.
Old Nov 4, 2005 | 01:47 AM
BFG9000's Avatar
BFG9000
You'll gain a CEL in the dash when the 2nd O2 sensor detects it is not working. Modern cats are pretty low-restriction; about like a resonator. Certainly better than those abominable 200cfm pellet-type GM catalysts in the 70s that made the Corvette go 0-60 in 9 seconds.
Old Nov 4, 2005 | 04:24 AM
onasled's Avatar
onasled
You will get a raspier and bit louder sound in the exhaust.
Depending on your mods your Mini will be a bit livelier, a bit quicker and a bit stronger in the higher rpm.
And yes, you will get the dash light.
Old Nov 4, 2005 | 07:44 AM
little egg's Avatar
little egg
If you live in the "Peoples Republic of California" they will take your car:impatient
Old Nov 4, 2005 | 07:46 AM
The Short Bus's Avatar
The Short Bus
I try to remove the cat everytime i drive.
Old Nov 4, 2005 | 07:55 AM
DizzyTT's Avatar
DizzyTT
In the EVO, a high flow cat is worth about 7-10, and a test pipe (open pipe) is worth 20hp
Old Nov 4, 2005 | 08:09 AM
Gr8Force's Avatar
Gr8Force
Ask kaeleria, he's been trying to remove a cat from his car forever.
Oh, you're not talking about that kind of cat. My bad.
Old Nov 4, 2005 | 12:52 PM
Profpatpending
Hmmm sounds interesting 20 ponies.
does anybody have a little more accurate info regarding the cat restrictions,
I know some of the twincharge kits do away with the cat altogether e.g. SPI
so there is a way of fooling the second o2 sensor into thinking the cat is still there maybe place a resistance across the sensor.
anyway the numbers im more interested in.
just want to know if the cat was bypassed would the gains be noticeable,
I mean going from stock to 15% noticable?????
Old Nov 4, 2005 | 01:00 PM
Tüls's Avatar
Tüls
Turbius Maximus
I gained about ten WHP (dyno jet WHP) but that also needed to be tuned to see it...
the thing with an EVO or any turbo car...less restriction ...better spool...more power...and sooner to boot.
Old Nov 5, 2005 | 03:07 PM
Bisch's Avatar
Bisch
...unplug the wires on the second O2 sensor. That has been done without throwing the light.
cawwwtun
May 3, 2016 08:03 AM
greekzilla
Aug 23, 2015 03:44 PM
PhoR53
Aug 21, 2015 05:10 PM
Aug 21, 2015 10:36 AM
rckrzy1
Aug 11, 2015 06:06 PM
