Drivetrain Aftermarket-Lower Final Drive Ratio-MCS
Old Nov 21, 2005 | 01:16 AM
  #26
MadMick's Avatar
MadMick
Our fastest minis runs 160 mph (gps confirmed) and hit 6800 rpm in 6. gear with the old long ratio gearbox. To reach this speed, at least 255 hp at the crank are required.
The facelift gearbox has the perfect gear ratio for a well tuned ccoper S.
Old Nov 21, 2005 | 04:26 AM
  #27
Cosmic Purple's Avatar
Cosmic Purple
What is the facelift gearbox?
Old Nov 21, 2005 | 04:55 AM
  #28
MadMick's Avatar
MadMick
There wa a facelift, from `04 the cooper s are equipted with a shorter final gear ratio.
Old Nov 21, 2005 | 06:26 AM
  #29
Cosmic Purple
Thanks, I understand what the facelift is now. I thought you meant another setup.
Old Nov 21, 2005 | 06:52 AM
  #30
n3nyongmini's Avatar
n3nyongmini
'Mick - what tire size we're y'all running?
Derek
Old Nov 21, 2005 | 07:20 AM
  #31
MCLeonard's Avatar
MCLeonard
Can you tell us how long of a run it took to reach 160?
Old Nov 21, 2005 | 08:09 AM
  #32
warchieft2k's Avatar
warchieft2k
here is the mini gears for a 2003:
Gear -> Ratio for Stock 'S' -> Speed @ 7000 rpm Stock 'S'
1st -> 11.418 -> 43 mph
2nd -> 7.176 -> 68
3rd -> 5.399 -> 91
4th -> 4.41 -> 111
5th -> 3.652 -> 134
6th -> 2.984 -> 164
hope this helps...
Old Nov 21, 2005 | 08:46 AM
  #33
jblow's Avatar
jblow
IIRC, the gear ratios changed for the '05 model year -- my '04 MCS has the earlier gearing.
Old Nov 21, 2005 | 12:23 PM
  #34
MadMick's Avatar
MadMick
The tire sizes are usualy 205/45 17" or 215/40 17" or 205/40 18" all aproximately the same (stock) diamieter.
You can reach quite fast about 120 mph, i was exactly as fast as an stock Nissan 350Z and from 30mph to 100mph exactly as fast as an stock Mitsubishi Evo.
But it takes centuries to reach 160mph........
Old Nov 21, 2005 | 12:44 PM
  #35
MCLeonard's Avatar
MCLeonard
That is what I was thinking. If you look at the Superfour article in the current issue of Car and Driver a Mini with 265 hp and over $50,000 invested reaches 100 mph in just over 14 seconds but takes more than another 13 seconds to hit 130 mph. It only gets slower after that. You would need to be in the out back to find a road that is long enough to get to 160.
Old Nov 21, 2005 | 02:31 PM
  #36
chows4us's Avatar
chows4us
Our fastest minis runs 160 mph (gps confirmed) and hit 6800 rpm in 6. gear with the old long ratio gearbox. .
Madmick, who is "our"? A racing business?
Old Nov 21, 2005 | 03:00 PM
  #37
MadMick's Avatar
MadMick
Just the "racing" business on our german autobahn without any speed restriction!
It is a very hard business for our tuner to keep the power and engine durable as we can drive the cars on the autobahn for dozens of miles WOT.
Old Nov 21, 2005 | 03:12 PM
  #38
chows4us's Avatar
chows4us
Ahh, didnt know you were in Germany ... BIG difference
Old May 2, 2011 | 09:45 AM
  #39
srdks's Avatar
srdks
2nd -> 7.176 -> 68
3rd -> 5.399 -> 91
4th -> 4.41 -> 111
5th -> 3.652 -> 134
6th -> 2.984 -> 164
hope this helps...
Very useful.
Does anyone have the specs for facelift cars?
Old May 4, 2011 | 03:32 PM
  #40
srdks's Avatar
srdks
None?
Old May 4, 2011 | 05:29 PM
  #41
cmt52663's Avatar
cmt52663
this is dated Sept of '06 if I read it correctly - is this what you seek?
http://www.mini2.com/forum/attachmen...4&d=1167862092
Cheers,
Charlie
Old May 5, 2011 | 08:31 AM
  #42
srdks's Avatar
srdks
Not exactly. I am looking for how many miles per hour each gear have on 7000 rpm for mini Cooper s r53 f/l.
But thanks for your interest.
Old May 6, 2011 | 08:28 PM
  #43
JumpingJackFlash's Avatar
JumpingJackFlash
Originally Posted by cmt52663
Interesting link, except it indicates R55-R56 ratios, not R50-R53 ratios. Here's a thread that explains all the different gear ratios: https://www.northamericanmotoring.co...rans-swap.html. The reason 3/4 and 5/6 ratios are the same is because the Getrag has dual shift forks. Transmission gears 1/2/5/6 have a 2.74 ratio equivalent (to an actual rear end gear set) and gears 3/4 have a 4.05 ratio equivalent. Effectively, R53s have no overdrive gear, which is why they pull really well in 6th gear above 70 MPH.
I will say from experience it takes a good bit of time to get from a buck-twenty to a buck-thirty on the speedo. Even if the theoretical top speed is higher, you're gonna deal with wind resistance that requires more HP to overcome. Besides, top speed is only really effective in a straight line. It's more about maintaining a higher speed in the twisties, whether you improve your engine mods, suspension mods, or both.
Teh
Jun 13, 2018 02:59 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
Dsinkster
Aug 17, 2015 03:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
