Drivetrain SSK's that fit with JCW resonator?
Old Oct 14, 2005 | 09:28 PM
XAlfa's Avatar
XAlfa
I'm assuming the Alta can be adjusted to a length that works, but not sure what kind of throw reduction I'd end up with. Has anyone fitted the Alta or any others along with a JCW resonator?
Thanks!
Old Oct 16, 2005 | 01:13 PM
XAlfa's Avatar
XAlfa
Have I found a void in the vast NAM knowledgebase? Hard to believe.
Old Oct 16, 2005 | 01:51 PM
schooner2's Avatar
schooner2
I have an 04 jcw with a alta short shifter, I did have it set positon 2 wich allows the cover on the bottom to remain, if i went to postion 3 which is 45% reduced but the cover has to come off, at postion 2 i have estimated the reduction about 37% and it is fantastic, on another note i have now removed my resenator and it sound awesome and better gas milage, my mini tech that installed the short shifter did not say if I would have a problem if I had gone to postion 3 so I am not sure if this info helps you in anyway but there is my 2cts
Old Oct 17, 2005 | 09:33 AM
XAlfa's Avatar
XAlfa
That helps a lot. Thanks!
Jan 4, 2019 12:51 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
