Drivetrain Speed limiter removal
Is there anyways to remove the Top Speed Limiter on the Mini? I realize that the MTH software can raise your Rev Limiter but can it also raise the Top speed limiter? What about other solutions? Anyone have any idea?
Thanks,
Jm
Thanks,
Jm
Dinan software upped the rev limits, changed the mapping and removed the speed limiter for me on a BMW, there is a good chance the software for the Mini is similar (check the website, dinancars.com).
Originally Posted by Wagnbat
There's a speed limiter?
I've taken my Mini a tad passed 115mph, and not noticed any type of governing.
. A little over 135 it slows fuel delivery and you're limited. I believe every software that I've seen does remove it. Mine will be doing so...
Originally Posted by ingsoc
The speed is 'soft limited' from my experience
Originally Posted by dominicminicoopers
Do you think slowing fuel delivery on a mod'd MCS (running over 20+lbs of boost) would lean it out too much?
I don't believe they would just cut-off fuel. I think it will give less gas and close the TB butterfly to an appropriate angle to match air mass to the fuel delivery, but I can't say for sure.
Originally Posted by Abbett
Do all MINIS have a speed limiter or just US spec cars? JCW specifications list top speed as 143mph.
The digital (if you have the on board comp) will show the actual speed without error (what MINIusa told me). Also to get to the top speed you have to have it in fifth gear in the S. If not (this is on a track test of mine) you only get up to about 130, in sixth.
so there is no way to get the MCS over 135 unless you remove the limiter? I hit 132 in 5th and still had a little more to go before hitting rev limiter. If one were to shift to 6th after hitting rev limit in 5th, the car would just kinda die until you were under 135?
not sure about either statement; both digital and analog should show the same speed, and in my car both are at least 2 mph too fast around 80 mph (radar & GPS checked). And as far as I remember I run out of rpm in 5th gear so to go faster than 130 I have to shift to 6th...
Originally Posted by tradiuz
I think the speed limiter is just downright inconvenient. Having only crossed 130 twice, I dont see why its there. When you're going that fast, why kick in? Afraid of tires exploding?
It's hard to find any straight roads here in North Georgia. About all we got are these crazy twisties which really limit us to about 90 MPH tops before we have to stand on the brakes. I guess we can't have everything
Hmm thats weird... are you shifting at redline or taking it to rev limit in 5th. I was just passed redline when i was going 132... I think the car can do 135 at rev limit/top speed limit in 5th.
Yeah here in miami theres a few highways where you can really test the car... provided theres no one in the way of course...
In many cases speed limiters arent what is hindering your top speed. Many times its the HP versus aerodynamics. I forget where it was, but i saw a test concerning the MCS saying that you would need to get more power in order to get the speed faster.
