Drivetrain Whats this wire?
Old Sep 30, 2005 | 07:09 PM
mdsbrain's Avatar
mdsbrain
Whats this wire?
I was trying to install a Alta CAI on a friend's 02 MCS when I encountered a weird wire. Its pictured below. This wire comes through the partition and into the fuse box. Its circled in red
Old Sep 30, 2005 | 09:01 PM
glassintrepid's Avatar
glassintrepid
Some kind of aftermarket something, what does the car have on it? Non MINI driving lights?
Old Sep 30, 2005 | 11:33 PM
Discosmurf's Avatar
Discosmurf
It doesn't have any aftermarket parts to it. The lady I bought it from was a non-modder, so to speak. It has the Xenon headlights and the rally lights, but that's it. Nothing else, as far as I know. The CAI is the first mod ever done to the car.
Unless the dealership decided to put something special in there and not tell anyone....
Old Sep 30, 2005 | 11:59 PM
1nf3rn0's Avatar
1nf3rn0
The rally lights might be what intrepid was refering to...
Old Oct 1, 2005 | 05:57 AM
mdsbrain's Avatar
mdsbrain
Hmmm..maybe we could reroute the wire or make the heatshield for the CAI a tab smaller to avoid the wire. I like the reroute the wire idea better though
Old Oct 1, 2005 | 08:49 AM
Ryephile's Avatar
Ryephile
That wire IS for the dealer-installed driving lights. Be happy they did that clean of a job, usually the dealership monkeys just hack it up.
Old Oct 3, 2005 | 05:35 AM
Pir8 97's Avatar
Pir8 97
I had the same thing... had to enlarge the hole in the firewall to get the end through.
Old Oct 3, 2005 | 05:44 AM
mdsbrain's Avatar
mdsbrain
I'm confused..so what can I do with the wire to allow for the Alta heatshield to fit? Do I need to trim to the heatshield?
Old Oct 3, 2005 | 06:13 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The wire should be long enough to route it around the alta shield. Best to do is come up from below, possibly where the wiring harness goes through the partition to the fusebox (the grommet is split, so you can incluse the wire next to it without any problems). Follow the big red wire up into the fusebox and you are set. Use a zip tie to hold the wires together down below.
Old Oct 3, 2005 | 10:20 AM
Bugs's Avatar
Bugs
I may be looking all wrong, but isnt that the rear shield which getds removed for the intake install?
Old Oct 3, 2005 | 10:27 AM
mdsbrain's Avatar
mdsbrain
Yes it is. But in this case we wanted to keep the peice in. But either way this wire runs through the shield.
Old Oct 3, 2005 | 10:28 AM
agranger's Avatar
agranger
Does it have LoJack?
Old Oct 3, 2005 | 02:12 PM
Discosmurf's Avatar
Discosmurf
I don't think it has lowjack.
Old Oct 3, 2005 | 04:19 PM
Turmoil's Avatar
Turmoil
It has to be driving lights... unless he has an amp installed thats aftermarket or he tried to retro fit HK system...
I would guess its driving lights... worse case scenario, drive it over to a Mini service rep and have them check it out.
OutMotoring
Mar 3, 2017 06:29 AM
SJ-R50
Oct 28, 2015 08:39 AM
papawhiskey
Sep 30, 2015 02:50 PM
dragonby
Sep 25, 2015 08:10 PM
