Drivetrain wires
Old Jan 29, 2003 | 08:42 AM
SMG's Avatar
SMG
anyone tried the magnocor spark plug wires??
Old Jan 29, 2003 | 09:00 AM
nfo's Avatar
nfo
yo smg. do a search, randy has some stuff to say about them.
from what i remember he said they were worth getting!
Old Jan 29, 2003 | 09:04 AM
SMG's Avatar
SMG
just did the serach.......no matching.....
Old Jan 29, 2003 | 09:11 AM
2minis's Avatar
2minis
I don't know if Randy is around so......
I know he likes the Nology....but for
the $$$$ I'd go with the Magnecors and
Randy has them as well as Nology.
Old Jan 29, 2003 | 09:22 AM
8ball's Avatar
8ball
>> ... but for the $$$$ I'd go with the Magnecors ...
That's why I went with the Mag's - yeah, I took the red ones ...
They didn't make 20 hp or anything but there is a perception of
being smoother, particularly at lower RPM's ...
Old Jan 29, 2003 | 09:25 AM
SMG's Avatar
SMG
8ball, did u change the plugs too?
Old Jan 29, 2003 | 09:31 AM
8ball's Avatar
8ball
The stock plugs are fine ... I don't think changing to a different brand or design or different metal tip would make the difference .... brand loyality is a powerful thing but MINI put a good one in as std. equip. IMHO ...
Old Jan 29, 2003 | 09:35 AM
dominicminicoopers's Avatar
dominicminicoopers
I've heard that although the engine runs smoother that there is actually some Hp/torque LOSS by installing them. Any claimed HP gains have never been proven by independant/unbiased testers. This goes for other cars as well.
From my research, here's what you're paying for:
1. Cool looks in the engine compartment
2. Smoother engine idle.
3. Mild loss of power
Not worth it for me...
Old Jan 29, 2003 | 09:44 AM
8ball's Avatar
8ball
... I think there may be a hp loss at the peak (what is that? 6000rpm?) but there is a 'fattening' of the curve - more at the midrange - where most of us spend our time; day-to-day cruising around 3k-4k as we fight through rush hour is where we need the gains ... but, yes, blasting free of the pack with higher rpm's is fun too - don't want to sacrifice too much up there
Old Jan 29, 2003 | 10:39 AM
chrisneal's Avatar
chrisneal
SMG - don't use the search window at the top right of the screen. It does not search the forums! Click on the word 'search' to the right of the drop-down menu that says the name of the forum you're currently in. I did a search for magnecor (make sure you spell it correctly, too) and got a long list of threads.
_________________
2003 Red/White Cooper - Brookline, MA
Old Jan 29, 2003 | 10:36 PM
SMG's Avatar
SMG
i can finally "search" the forum, tks chrisneal.
just got the wires today.....mines are black instead of red or other colors....
i noticed NO difference at all.
Old Jan 30, 2003 | 07:16 AM
chrisneal's Avatar
chrisneal
I've got the red Magnecors, and the one difference that I noticed was that they eliminated an uneven idle thing that my car sometimes did - it would idle steadily at one rpm (something around 1100, I think), and every 5-10 seconds or so, would drop down slightly and come back up. Doesn't do that any more.
Old Jan 30, 2003 | 07:36 AM
dominicminicoopers
Don't just search here. I did research in other car forums (different Make and Models of autos). It kinds sounds like religious banter. No one can prove on a dyno any increase other than the manufacturers. When independants check them, they notice no or a little loss in HP. So you can listen to the teenager's "seat-o-pants" dyno (aka butt dyno) results and associated placebo effects, or you can take it from unbiased people's testing. If you're after smoother idle and cool looks. go get them. Looking for performance increase...hmmm...
Old Feb 13, 2003 | 01:55 AM
aVjai's Avatar
aVjai
Hi i got the nology wire.~ it run GREAT~ i can really feel the different.
but one problem i got is the battery light keep going on.
and sometime it go off. like 2 second.. when the car go slow, or stop it pop back out again. anyone have this ???
anyone know why is like this?
Old Feb 13, 2003 | 04:35 AM
Nobull60's Avatar
Nobull60
I got the Magnacor wires. Had them for a while now. No complaints and they look good to.
Old Feb 13, 2003 | 07:39 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I'm not sure, but from the list of stereo equipment you have, I would guess the alternator is having a tough time keeping up with the voltage/amperage requirements at idle.
The alternator is driven off of the engine, so with an increase in RPM, the alternator is capable of producing more power. It is regulated by the voltage "regulator" which keeps it from producing too much.
If the battery light is triggered by a low voltage condition, you may see it at idle when the power available from the alternator is at its lowest. The wires may have been enough to send it over the edge.
As long as it is just a flicker - as in when the idle drops down a bit when coming to a stop - I wouldn't worry about it. If it's steady, it may be time for you to research a higher output alternator to run that really cool sound system.
Let me know if you have any other questions.
Randy
randy@mini-motorsport.com
Old Feb 13, 2003 | 05:15 PM
truckeecollins's Avatar
truckeecollins
I used Magnacore wires on my 914 and they made a slight difference in my autocross times. You might check the report in Grassroots Motorsports mag. They did a great test on products for their autocross MC that included dyno testing each product independently.
Good Luck
RED MCS on the ship Titus as I write
Old Feb 24, 2003 | 08:38 AM
MCSHP's Avatar
MCSHP
anyone out there Install these Nology wires on a Cooper S? If so where are you attaching the grounding straps to each of the wires?
Old Feb 24, 2003 | 01:30 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
>>Thanks
Use the rear intercooler mount bolts - not the ones that keep the plastic cover on, but the bolts that go into the block that hold the attachments for the plactic cover bolts.
1&2 go to the pax side, 3&4 go to the driver side.
Feel free to call me if you need help.
Randy
720-841-1002
OutMotoring
Mar 3, 2017 06:29 AM
SJ-R50
Oct 28, 2015 08:39 AM
papawhiskey
Sep 30, 2015 02:50 PM
dragonby
Sep 25, 2015 08:10 PM
