Drivetrain Software question
Old Sep 17, 2005 | 07:49 AM
adis_daddy's Avatar
adis_daddy
Software question
I am currently running the EVO Tech ECU software. I just purchased the Unichip and don't want to install it until I am certain the two don't conflict each other and I'm left with a broken car or one that won't work properly.
Anyone out there able to put my mind at ease so I can install this puppy?
Old Sep 17, 2005 | 07:58 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Have it flashed back to stock before you install the Unichip. The Unichip does not deliver specific results, it only changes the A/F and timing a percentage from what's already in there. You could end up with a much worse performing car and/or cause damage if you try to run the two on top of eachother. See this post for what the Unichip actually does:
https://www.northamericanmotoring.co...0&postcount=42
Old Sep 17, 2005 | 08:14 AM
gjpundsack's Avatar
gjpundsack
Keep the EvoTech. Have it updated.
adis_daddy's Avatar
adis_daddy
WOW!!! Do I send it back and not install at all? Not that I don't like the EVO Tech, I just like the idea that I don't have to worry about the dealer overwriting the software and have to have it reflashed, again.
Old Sep 17, 2005 | 08:25 AM
gjpundsack's Avatar
gjpundsack
If that were to happen, I would expect your installer to reflash the EvoTech at no charge.
Old Sep 19, 2005 | 08:58 AM
gt5816v's Avatar
gt5816v
As Andy said don't run the two together. It will probably run way too lean! The effects of the two products are cumulative and will not be beneficial.
Old Sep 19, 2005 | 12:19 PM
adis_daddy's Avatar
adis_daddy
Marginal gains at best with the Unichip. Have opted to return it and continue dealing with having to have EVO Tech reflashed any time the dealer updates the ECU. A pain in the butt but for 2 or maybe even 3 hp not worth the $750 IMHO
Can you say upgrade brakes for $750
Old Sep 19, 2005 | 12:40 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Andy, I could kiss you, I've been looking for that post for a few days.
Bahamabart's Avatar
Bahamabart
is that all you get - 2-3 hp w/ the unichip? the website inferes much more. what do you get with evotech? I want to do a ecu upgrade but can't figure which way to go.
Old Sep 23, 2005 | 10:33 AM
gt5816v's Avatar
gt5816v
Do you have the actual dyno info from the two programs? I'm sure Andy would love to see it
iclancy82
Jan 2, 2021 08:59 PM
donniedarko
Oct 21, 2015 01:15 PM
molala
Oct 2, 2015 01:53 PM
rob&JCW
Sep 10, 2015 12:06 PM
Richard Kellstrom
Sep 4, 2015 07:21 PM
