Drivetrain 400cc or 380cc injectors.....
Old Sep 10, 2005 | 03:19 PM
d6-mcs's Avatar
d6-mcs
whats up...i am running cai...19% pulley....header...schrick cam....exhaust...water intercooler....dinan TB....dinan stage 5 software...plugs...dinan wires...on the stock injectors....not having to many problems but i want to upgrade the injector just so i know that i have enough fuel running to not go lean on WOT.....i dont know if i should run some 380/jcw's or go with something bigger like 400cc.....injectors....need some help on this....thanks
BATES
Old Sep 10, 2005 | 03:24 PM
isellem's Avatar
isellem
380's will get you done with those mods! if you plan on doing nitrous or anything else like that you would want to consider larger...
but we are running 380's (JCW) on a car with a cylinder head, schrick cam, port matched intake manifold, exhaust, header, cai, obx header no cat, and evotech stage 6 software and everything is perfect!
hope i helped...
bottom line though... you won't need anything larger than 380's but i would just buy which ever ones you get a better deal on because the extra 20cc's wont hurt
Old Sep 10, 2005 | 03:31 PM
d6-mcs's Avatar
d6-mcs
right that is where i am thinking of running the 400cc...specially when there only 20bucks more then the 380s...
BATES
Old Sep 10, 2005 | 04:05 PM
ingsoc's Avatar
ingsoc
The 20 extra cc's will be 20 more that you need to calculate into your engine tune, mind you... If you don't custom tune with either, you will run rich and lose a few mpg, moreso with the 400s. That said, you should be getting a new tune with any new injectors anyways, so the 20 extra cc's will easily be bonus/insurance .
Old Sep 11, 2005 | 01:13 PM
isellem's Avatar
isellem
true... but the 380's aren't even close to being maxed out with those mods... if you plan to do more mods... then yes the 20ccs are the bonus and will give you "room for improvement"
but all in all... you can't go wrong with either one! Just get them from who you trust the most or have the best relationship with or get the best deal... i wouldn't let the 20cc's be a determining factor unless you are planning on doing a lot more mods to warrant the need of the extra 20cc's
KinetechMW
Sep 10, 2015 03:12 PM
Manny_cooper
Sep 3, 2015 05:48 AM
Manny_cooper
Aug 31, 2015 05:04 PM
shunderwunder
Oct 2, 2007 04:50 PM
Hounddog
Dec 1, 2005 04:29 PM
