Drivetrain Nitrous
Old Jan 7, 2006 | 06:23 PM
  #26
cooper99's Avatar
cooper99
I read something like this a while back ago on some site, but I thought it was really funny...
You can compare nitrous with Viagra in many ways. It gets you going fast, safe to use in modest amounts, isn't quite the real thing but sure gets the job done, its predominantly used by males, you can get refills when you are out, and its something you try to conceal from others.
Old Jan 7, 2006 | 06:27 PM
  #27
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
You can compare nitrous with Viagra in many ways. It gets you going fast, safe to use in modest amounts, isn't quite the real thing but sure gets the job done, you can get refills when you are out, and its something you try to conceal from others.
Old Jan 7, 2006 | 08:02 PM
  #28
MSFITOY's Avatar
MSFITOY
Are you implying that I'm gettn old And for the record...Viagra does work ooops...did I just say that? I've got a big mouth
Old Jan 8, 2006 | 07:15 AM
  #29
ingsoc's Avatar
ingsoc
Just watch out for the priapism . You don't wanna be rushed to the ER for THAT.
Old Jan 9, 2006 | 03:01 PM
  #30
willy69's Avatar
willy69
i am running a 15%+4% pulley set up, ported head with 1mm bigger valves, cai, mth software, and custom exhaust. i want to add a 50 shot m7 kit, can i still use the mth software? the car is plenty fast for the twisties, need more hp for the drags.
Old Jan 9, 2006 | 03:36 PM
  #31
MSFITOY's Avatar
MSFITOY
I would be very careful mixing remapped ECUs and Nitrous. They typically lean out A/F to gain hp...the opposite of what you want to do while introducing Nitrous! I'm running Unichip but have monitored my A/F carefully. With similar setup as yours but 15%+2%, I use no more than the green nozzle which is equivalent, to best of my knowledge, a 60hp addition along with 400cc injectors and my A/F is running borderline around 12.5 to 13. I wish Unichip had the ability to automatically switch off during Nitrous...wishful thinking To date, it hasn't fulfilled even one promised external control I would in your case of 19% total pulley reduction, add 400cc injectors and use the red injector which is good for 40hp.
Old Jan 9, 2006 | 04:20 PM
  #32
willy69's Avatar
willy69
hey msfitoy,
how long do you run on the bottle? i mainly want it for street use, 2nd and 3rd gear. i have a k&n a/f monitor that i will install to monitor. do you think i can use the 60 shot?
Old Jan 9, 2006 | 04:39 PM
  #33
Johan's Avatar
Johan
I thought with the venom system it tells the injectors to go to 100% duty cycle by overriding the computer. So it doesn't matter what your computer says about fuel right? Is anyone here running MTH tuner with M7 nitrous kit?? Did you have to get a special tune?
Old Jan 9, 2006 | 08:54 PM
  #34
M7's Avatar
M7
The problem is not in the fuel injection map, but the advance of the ignition, which is usually part of software tuning.
Team M7
562-608-8123
Old Jan 9, 2006 | 09:20 PM
  #35
mybroscoop's Avatar
mybroscoop
hehehe that would be BAD! My moms a nurse.
Old Jan 10, 2006 | 12:06 AM
  #36
MSFITOY's Avatar
MSFITOY
Team M7
562-608-8123
You're right Peter...thanks for the correction
Old Jan 10, 2006 | 12:19 AM
  #37
iHeartTSB's Avatar
iHeartTSB
IQRaceworks
53
Jun 28, 2024 07:29 AM
CPEWEGO
Dec 10, 2004 10:10 AM
GRENDEL
Dec 30, 2003 10:27 AM
M7
Nov 28, 2003 03:24 PM
