Drivetrain How much HP can i expected with this?
Old Aug 27, 2005 | 07:36 AM
electricblue's Avatar
electricblue
I have a mcs '05 is eb/w sport web wheels and white stripes.and i want to added alta cai,15% pulley,giac ecu,2% crank pulley,obx header,miltek exhaust,m7 400cc injectors,m7 throttle,alta big intercooler and the question is . How much HP can i expected and more or less what time in a 1/4 mile?
Thank's for all the advised!!!!!!
This side is really fun ....
Old Aug 27, 2005 | 09:02 AM
kyriian's Avatar
kyriian
i'd wager about 200 whp.... close to 240 at the crank...
but then likely speculations, do a dyno run before and after and show us the gains!
Old Aug 27, 2005 | 10:13 AM
Minirox's Avatar
Minirox
Just did a drag day with the PSMINI.ORG Club. There were 2-JCW an 05 and 04 1- 02 MCS/Dinan stage 5 1-03 MCS (Mine see mods below) 05 MCSC 17% pulley. 03 MCS Stock. The stock ran 15.8 the others ran 15.2 to 15.6. The JCW,Dinan and mine were with-in 100ths of a second apart. You can expect 200hp + and low 15s or high 14s in the 1/4 mile.
Old Aug 27, 2005 | 11:11 AM
electricblue
thank's guys when i put all the stuffs i test in the dyno and tell you how much it gain. that's more or less what i want to gain.
Old Aug 27, 2005 | 11:13 AM
ingsoc's Avatar
ingsoc
I don't think that'll make the magical 200 whp. I am guessing low 190s at most. This also depends on how 'strong' your car is from the factory. You willl almost certainly need head work to get to 200. All of the breathing apparatii (in and out) will be limited by the amount that you head can flow somewhere in the 190 whp range, I honestly think. I also don't know what the giac ecu will do. It doesn't have stellar hp #'s, from what I've seen. You'll definately need colder plugs with the mods above, also. Good luck!
Old Aug 27, 2005 | 01:38 PM
electricblue
hi thank's for advised but let see how much hp i can gains with out touch the head at this moment remember this monday the dealer give me my mini.and i want to put only bolt-on parts in case of any damage don't lose the waranty.
Old Aug 27, 2005 | 02:30 PM
ingsoc's Avatar
ingsoc
Look for the posts by JCampos where he says that he was trying to get 200 without touching the head and cam. You'll see that he did just about everything possible and was using a custom Unichip, but last I heard he had not reached it. Good luck, though! A lot of people have been hoping it was possible.
Old Aug 27, 2005 | 03:25 PM
electricblue
thank's
as soon as i put all the mods i give you my results.for more advised if i needed.
Old Aug 27, 2005 | 04:42 PM
isellem's Avatar
isellem
i have a 15% pulley and a jcw intake and injectors... thats it... i run 14.6-14.8's consistantly... (dependant on whether conditions and how many runs i make... when it gets heat soaked i start to run the 14.8's) This is with stock everything else including crappy runflat tires and s lites...
ohh yeah and these were all run when the temp outside was between 95-110 degrees in hot a$$ PHOENIX!
Old Aug 27, 2005 | 05:35 PM
electricblue
you don't have header,exhaust,throttle,ecu with only those mods it runs hard!!
Shomare
39
Oct 19, 2015 03:33 PM
Fordgt4
Oct 10, 2015 10:42 AM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
