Drivetrain First Track Test for new M7 2% Crank Pulley
Old Sep 15, 2005 | 03:15 AM
  #26
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
And the accessories spinning 4% faster? The a/c and alternator are in the group, I assume? I don't understand the details of MINI's electronics, but would they be calibrated to a particular output from the alternator?
dan
Old Sep 15, 2005 | 11:26 AM
  #27
D_Nyholm's Avatar
D_Nyholm
That is another question I have as well. I am interested in getting the 4% pulley, but am concerned about the other accessories spinning at a higher speed when at redline. I am thinking I should take a safer step and just get a 2%, but of course, the 4% is the same money, so why wouldn't I get it since i have no supercharger pulley on the car (though I may consider a 15% Alta pulley in the future).
Old Sep 15, 2005 | 01:28 PM
  #28
bouray's Avatar
bouray
Alta is working on an underdrive alternator pulley as they have indicated. I don't recall seeing an anticipated delivere date. AC is another issue. Eurosporthighperformance.com in UT has an underdrive alternator pulley currently. Price is $59 and it is chem coated aluminum. It underdrives more than the 4% overdrive crank you say you are considering. Probably around -15%. I have read tests that at an idle with a stock crank no undercharging was reported even with a full accessory load.
Old Sep 15, 2005 | 02:00 PM
  #29
D_Nyholm's Avatar
D_Nyholm
Well, with that information, I might as well just get the lightweight crank pulley. I don't see the reason to have to spend an additional $150 or so on each of the other pulleys. The alternator pulley is going to be a PITA to remove. I've never removed a a/c pulley, and I don't think you can with the built in clutch....
Maybe i'll just go along with a lightweight crank and a 17% supercharger pulley....
Old Sep 15, 2005 | 04:15 PM
  #30
mp5999's Avatar
mp5999
who makes the crank pulley w/ balancer??
Old Sep 16, 2005 | 03:19 PM
  #31
ingsoc's Avatar
ingsoc
pilo wanted to make one, but it's not out yet
Old Sep 17, 2005 | 11:10 AM
  #32
minibeel's Avatar
minibeel
Total brain-fart. Tell me if I'm wrong here. Going to a 4% pulley on the crank wouldn't hurt the accessories one bit. They spin at various speeds as the engine revs in normal driving anyhow, right? And, unless you are hell-bent on redlining at every opportunity, they would not "redline" themselves to the point of failure.
If that's correct, then we don't have to mess with accessory pulleys at all.
dan
Old Sep 17, 2005 | 11:39 AM
  #33
bouray's Avatar
bouray
Good point. Its only 4% right? Its not like your're doubling the rpms at the alternator or compressor. I think some folks that want their cake and eat it too, are the wet blanket on this one. Its an accessory for crying out loud with a limited service life(like the engine!). "I want my car to last as if it were never modified, but want the additional performance." Sheesh!!! If you want it to last, leave it in the garage.
Old Sep 17, 2005 | 07:39 PM
  #34
D_Nyholm's Avatar
D_Nyholm
Lol. I was thinking about it some more as well. If the engine is spinning at 6600 rpm and now you have a 4% crank pulley spinning the accessories 4% faster, they will only be spinning at 6864 rpm, which should be completely fine. I think i have read here that plenty of people have their rev limiter removed and track thier Mini's with a new 7000 rpm rev limit with no problems. If that is the case, I think I am pretty satisfied that it will be ok. The only thing I am thinking is that I might want to throw a 15% pulley on there later. Not too sure about putting 19% over-rev on the supercharger. Maybe i'll go with a 2% and a 15% so I get a 17% overall. I know, i know, people have done the 19%, but in my mind it just worries me. It isn't like 2% is really that much. I guess I'll see what comes out of this from some more searching around on the site. I'll probably end up with a 19% overall at some point!!!
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
mackedmini
Aug 20, 2015 02:35 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
