Drivetrain JCW intake install question
Old Aug 14, 2005 | 01:13 PM
dinile's Avatar
dinile
I need help with the wiring of the jcw intake, specifically the yellow wire. I believe it is to be spliced with a white and red wire from the ecu harness closest to the firewall. There seems to be 2 wires that may match the description and I would hate to cut the wrong one! One seems to be red with a white stripe, the other white with a red stripe. Also I'm not sure how to make the splice, do I cut the wire, and if so which end do I splice the yellow to? The one coming from the harness or the one from the ecu?
Old Aug 15, 2005 | 07:49 PM
supersand's Avatar
supersand
Hi,
I installed the intake a few months ago. If you unwrap the wires coming out of the connector you can trace the wire back to its pin location (pin 113) on the connector (it's written in really tiny numbers on the connector) the wire is yellow and its one of the larger wires in the bundle. Cut the pin 113 wire and splice all three together. I used a crimp connector and electrical tape to hold it all together. Probably nice to use a shrink fit sleeve if you have one.
hope this helps
Old Aug 16, 2005 | 03:01 PM
aminicooper's Avatar
aminicooper
Originally Posted by supersand
Hi,
hope this helps
Yea, what supersand said , mine's in w/ disconnect connector. Didn't have a hairdryer/heat blower to use with the supplied sleeve.
Supersand, does your wires out of the ECU/fuse box look clean? Mine looks 'odd', mine's tucked between the fuse cover and the plastic wall. If you have a pic, it'll be helpful.
Old Aug 16, 2005 | 03:04 PM
dinile's Avatar
dinile
Pin 113... thanks!
Alkaidovich
Jan 30, 2021 01:35 AM
silence2-38554
Nov 12, 2015 09:39 AM
Minibeagle
Aug 13, 2015 10:00 AM
papawhiskey
Aug 10, 2015 09:31 PM
