Drivetrain Heat management
Old Dec 8, 2005 | 08:17 AM
  #51
Dr Obnxs's Avatar
Dr Obnxs
Nothing really.....
Originally Posted by 62Lincoln
Matt, it's great that you're going to do this eval, but what will you do differently from what Keith has done?
But I'll do acetone rinses before each state. I also have a first gen ALTA TMIC that I'll throw into the mix. Even if the measurment is the same, think of it as "independant confirmation".
With all the HP numbers running around, some confirmation can't hurt.
So we'll get verification of the numbers, and a relative measurement to the ALTA first gen.
Matt
Old Dec 8, 2005 | 11:22 AM
  #52
62Lincoln's Avatar
62Lincoln
Old Dec 8, 2005 | 02:20 PM
  #53
Dr Obnxs's Avatar
Dr Obnxs
Plot thickens...
Cradin quoted $65 with them doing cleaning and masking, but there's shipping and turn around.
A local shop, Replika Maschinen, Inc., quoted $100-$130, but no shipping from where I am.
I've got a work trip for most of next week.... So I don't think the coating will happen for about two weeks....
Matt
Old Dec 8, 2005 | 05:40 PM
  #54
k-huevo's Avatar
k-huevo
Well, as you might be able to tell by my name, I have egg on my face. There is a huge problem with my over-simplification of the data. Yes indeed 4 C may equal 30+ degrees F but it does not mean that a 4 C difference from 36 C to 40 C equals a 39 degree F drop in relative temperature. I apologize for the inaccurate statements I made.
I recognized the problem when I started to compare percentages and again I am sorry for the mistake.
Old Dec 8, 2005 | 05:59 PM
  #55
ingsoc's Avatar
ingsoc
That is ok, man. We all make mistakes. Just don't get too upset by it... I'm sure everyone will agree that we appreciate your effort and thought. Some ideas work wickedly, others don't....but that's a part of monster, ain't it? Cheers and hope you have a good night!
Old Dec 8, 2005 | 06:16 PM
  #56
n3nyongmini's Avatar
n3nyongmini
Keith you are a model for us all - always professional, honest, polite and a gentleman; we should all do so well and resist anger or negative reactions as you do! I look forward to your next endeavor! Derek
Old Dec 8, 2005 | 07:04 PM
  #57
Dr Obnxs's Avatar
Dr Obnxs
Ah, eating crow...
a not too tasty meal that we have all had.
Matt
Old Dec 8, 2005 | 08:03 PM
  #58
k-huevo's Avatar
k-huevo
Thanks to those of you making the crow more palatable.
Matt, since you did some temp logging with the intercooler modifications, what was the most significant temperature change recorded in the intake manifold?
Old Dec 8, 2005 | 09:21 PM
  #59
Dr Obnxs's Avatar
Dr Obnxs
I'd have to dig pretty deep to see if I can find the data.
But the interesting thing is that in driving, the M7 scoop with a stock IC is almost as good as the GRS unit without the modified diverter. The combo of a scoop, and the GRS was best (as it should be). I'd hazard to guess that a coated stock IC with an M7 scoop would be as good as the aftermarket TMICs at much less $. Its an open question how well a coated aftermarket TMIC and scoop would do.
I think there is a lesson or 40 to be had here. If you do the TMIC mod, play with the diverter a la TonyB so that you don't waste any of the air. Otherwise less than perfect diverter design will compramise the potential benefit of the very expensive IC.
Matt
one thing I do remember is Tony mentioning that the GRS temps were higher, but I guess it had less back pressure, because the densities were greater. Remeber, it's not just temps, its pressure too. Most of the aftermarket ICs have much greater internal flow area, giving less pressure drop accross the IC. We don't have any data on Tony's modified diverter, other than his touch tests....
Old Dec 9, 2005 | 06:39 AM
  #60
andy@ross-tech.com's Avatar
andy@ross-tech.com
I'll take a gander at what you sent me so far ... sorry for the delay.
So far no one I’ve offered the data to has accepted the task of review. My results are only as good as the controls and I will admit they were not as tight as they could have been. If the outcomes are repeatable then we have something to get exited about and not just curious.
Old Dec 9, 2005 | 08:59 AM
  #61
TonyB's Avatar
TonyB
Originally Posted by Dr Obnxs
.... We don't have any data on Tony's modified diverter, other than his touch tests....
Indeed, I have not put the modifications through the same testing process to see how effective they truly are. And since I've done some other performance modifications to my MCS (not related to the IC) since that time, the results would not be ideal for comparison purposes. With that said, if I got cooler temps (IATs), it would speak even more highly for the GRS mods done...
The experimenting led me down a multitude of paths, almost consuming at times to where I was drawing stuff-up on the shower glass door! Got a really novel idea or epiphany a couple months back, and after cutting-up cardboard boxes, I decided to contact Peter of M7. I received some confirmation that it is certainly worthy of pursuit; and he is doing so, and along with his ingenuity, he is refining it with a top shop in the LA area. If this thing works as conceived, it will cool, and not only the charged air (most important), but also do a pretty decent job at clearing heat in the engine bay...
This was alluded to in another thread by Sid and Matt I believe, so this is not really anything new... just a bit more info I suppose.
Old Dec 9, 2005 | 10:20 AM
  #62
M7's Avatar
M7
[quote=TonyB]
The experimenting led me down a multitude of paths, almost consuming at times to where I was drawing stuff-up on the shower glass door! Got a really novel idea or epiphany a couple months back, and after cutting-up cardboard boxes, I decided to contact Peter of M7. I received some confirmation that it is certainly worthy of pursuit; and he is doing so, and along with his ingenuity, he is refining it with a top shop in the LA area. If this thing works as conceived, it will cool, and not only the charged air (most important), but also do a pretty decent job at clearing heat in the engine bay...quote]
Thank you Tony
Yes Tony and I have collaborated on this very unusual design, and after many months of contemplating IC core designs and life. We finally locked down the design and put it in to pre-production status. Without giving the store away.....I can guarantee all of you, that this "air 2 air" design is ground breaking and follows M7's "out of the box" philosophy. Product name "DFIC".
Sincerely
Peter
Team M7
562-608-8123
Old Dec 9, 2005 | 12:08 PM
  #63
ingsoc's Avatar
ingsoc
[quote=M7]
Thank you Tony
Sincerely
Peter
Team M7
562-608-8123
Oh jeesh, the cat! the hat! . It's good to hear the news break, Peter!
Old Dec 9, 2005 | 02:53 PM
  #64
jlm's Avatar
jlm
bag, not hat
Old Dec 9, 2005 | 03:04 PM
  #65
ingsoc's Avatar
ingsoc
Originally Posted by jlm
bag, not hat
or so you think! it was actually meant to be a silly little confounding clue, and perhaps one day it will all make sense . Link:
http://www.amazon.com/gp/reader/0394...3D#reader-link
Old Dec 9, 2005 | 10:16 PM
  #66
weezer2282's Avatar
weezer2282
I can’t get too excited about lower intercooler temps right now; I’m sitting here in a snowmobile suit because I have no heat and it’s 25 degrees with ice outside. On Saturday it was over 85.
I can't picture the snowmobile suit.
Old Dec 10, 2005 | 04:46 AM
  #67
jlm's Avatar
jlm
"With the announcement of a couple of new Top Mount Intercoolers coming out i figured it is about time to let ONE of our cats out of the bag." alta
Old Dec 10, 2005 | 05:52 AM
  #68
ingsoc's Avatar
ingsoc
They will not even come close to stepping on each others' toes . Trust me.
Old Dec 19, 2005 | 03:08 PM
  #69
Dr Obnxs's Avatar
Dr Obnxs
Cranking some numbers...
I took the 4.1 deg C average delta and worked some test number Andy had posted in this post: https://www.northamericanmotoring.co...0&postcount=44
Reworking the numbers, IC Thermal efficiency goes from
R1 68% > 74%
R2 70% > 86%
R3 70% > 75%
R4 68% > 73%
Note that Run 2 didn't look like it was running under boost, so take that one as a curiosity. But it looks like the coating will improve IC thermal efficiency 4%-5%. And this is at fixed internal flow restriction. While this doesn't seem like much, every bit helps if your seeing any timing retard due to knock loop intervention, or slight pinging....
JLM sent me a couple IC cores. They're off to get coated, and I'll reconfirm. I'm gonna send my gen 1 Alta off to get coated as well to see how it compares.
Matt
Old Jan 15, 2006 | 07:31 PM
  #70
k-huevo's Avatar
k-huevo
The latest item to get a ceramic coating; the pipes get hot but can still be touched, the canisters stay cool enough to hold, the tips won’t brand the shins.
Old Jan 15, 2006 | 07:38 PM
  #71
ScuderiaMini's Avatar
ScuderiaMini
wow Keith, that looks sweet, i always thought of doing this, but did not want to sound stupid and ask? Looks sweet, which is besides the point and the intention. Greg was mentioning about this yesterday, and i asked him if you were doing the CC on header or the whole system? Obviously it is the heat management, however could you possibly explain in details please?
Old Jan 15, 2006 | 09:11 PM
  #72
TonyB's Avatar
TonyB
Keith, I've been pondering the same! Did you have the coating done on the inside as well, minus the mufflers?
Old Jan 15, 2006 | 09:35 PM
  #73
Dr Obnxs's Avatar
Dr Obnxs
Omg!!!!
Adding weight? What drugs are you on!!! Where's the TonyB I know and what did you do with him?!?!? Next thing you know, you'll get those new M7 Strut Tower Braces, drive with a full tank of gas, 2 1/4r pounders in your tummy, and go over 2500 lbs!
Matt
Old Jan 15, 2006 | 10:10 PM
  #74
TonyB's Avatar
TonyB
It's me buddy! I do indeed have a penchant for weight loss... but I've actually done some mods that have added poundage:
driving lights
interior light
gauges (4)
toggles
shift **** (heavy Whalen)
Euro parcel shelf (heavier than knee bolster?)
aux input
dual cig lighter
oddment tray
and a few decals
Some coating to aid in hp, I'm all for!
Old Jan 15, 2006 | 10:18 PM
  #75
Dr Obnxs's Avatar
Dr Obnxs
What's this for?
dual cig lighter
For two cigs at once?
And the decals, that's wayyyy too much weight. But with the new ultimate power mod you did, you're wayyy ahead of the game.
Matt
