Drivetrain Anybody burn out their supercharger from running an aftermarket pulley?
Originally Posted by Itsdchz
I have heard from a VERY reliable chipmaker that there are people in Mexico running pulley's with a 24%, YES 24% reduction and have logged over 25K on them with NO problems...
Heresay does nothing to contribute to the conversation -- especially on a site that's 75% speculation in the first place.
Originally Posted by camelpilot
ANything that rotates over 19k rpm is bound to break.
Originally Posted by ryephile
Turbo's spin at well over 100k RPM all day long and have no trouble.
Originally Posted by detlman
But your statement was blanket that if it spins that fast it has to break.
:smile:
Here's a good read: Things Fall Apart: An Introduction To Entropy
:smile:
This is somewhat analogous to the lowriders that have little tiny tires on them - you know, the guys with the tires that stick out a foot from the fender wells with the sideways mudflaps. The speedo says they are going 70 while they’re actually doing 45 (in front of you the carpool lane of the freeway.)
Super Charger failure
Over on MINI2, there is a warning from a user about failures. It seems that sustained high boost will "overheat" the charger's rotors, and cause them to start shedding the coating, thus lose boost. The comment was related to tuneup time on a "rolling road" which I think means a Dyno.
The JCW Supercharger, and all production superchargers from some time in 2004, are supposed to have coated rotors. This allows closer clearence and higher boost, thus the 2005 has 7 hp more than the earlier cars.
I know that cars running 19% on the track have shred belts. I saw one at the 2004 EMW meet. The belt was really destroyed. I wonder if it is because the supercharger rotors heat up and grow enough to cause interference with each other or the walls of the Supercharger?
John
John
Maybe my logic is flawed but I believe that any moving component, especially bearings, have a finite service life. Working a component harder and at a higher speed can only serve to shorten its functional life. But, as with anything mechanical, there is a curve in service life and utility.
John
John
There are other threads on here about which belt to use on which pulley, if you're curious.
Originally Posted by countrym
I thought belt shredding was a result of poorly fitted belts. I doubt the rotors would heat up enough to cause interference inside the supercharger. That would be a lot of expansion, and it would seize the whole unit and cause a massive failure.
speaking of hearsay, the "special" thermal coating on the first issue of M7 pulleys was apparantly abrasive enough to whack belts; either that or the "special" groove design was doing it. Points to the need for care and testing in pulley design
"...the first run of pulleys where the thermal coating was too abrasive. We have since upgraded to a more belt friendly material and replaced the few that were sent out .
Randy
M7 Tuning"
Randy
M7 Tuning"
Lesson to anyone using a 19% would be to remove it if you are taking the car in for a power train issue.
You wanna play, you gotta pay.
I had my stock SC "fail" at 1200 miles. I had a squeal that sounded like the belt. Otherwise it ran fine. Replacing the tensioner & belt didn't help. They replaced the blower & the squeal went away. I'd like to hear the story behind yours, gclass.
Blow up wasn't the right term to use, sorry about that.
Let me put it this way, when you ge that supercharger spinning that fast for extended periods of time things tend to malfunction. Nothing "blows up". Bad choice of words on my part
when you say track car do you mean a dedicated track car or even occasional track use ? I get out on th etrack a few times a year and run the car HARD wil 19% pose a problem?
Originally Posted by onasled
I think he means that the cars are dedicated track cars, but note, I think they run well over 6950 rpm. Is that correct Matt?
Originally Posted by gclass
This will sound a little bit crazy. But I had a SC failure using a 15% pulley approx. a month ago. I will post pictures if you guys are interested...
This is true. Apparently the company that coats the pulleys for M7 applied the wrong coating. My belt was pretty much destroyed in three weeks and was actually already squeaking after about a week due to the abrasive coating. M7 notified me about the issue before there were any problems - only a few days after the pulley was installed. They replaced the pulley and the belt (at their cost, of course), and now it has been running great for a month or so, including a long track day. The pulley still has a coating, but it's the "correct" one now.
Randy
M7 Tuning"
Randy
M7 Tuning"
Sc
Well a month ago when i got to work i noticed a rattling sound coming from the internals of the SC and started to worry because everything else (external) was looking just fine. After work i drive home and the car was running ok (Producing boost) but the rattling sound was getting worst and worst. So i stoped and decide to tow it to my house.
Day after, when i took the SC i found out that one the gears in the secondary housing (The side that move the Water pump) was bended making the SC rods to vibrate and scratch with the walls. I'm at work right now so i'll be posting the pictures for you guys to see it.
Well in my case my car i heavily moded and I use it almost every day and travel like 30 miles to go to work.
Just posted in the vendor announcements, a "23%" dyno....
https://www.northamericanmotoring.co...050#post579050
alistaircookie
Oct 8, 2015 10:52 AM
gmonde
Sep 8, 2015 06:37 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
. Great improvement in TQ when the fuel could keep up.
