Drivetrain Just installed M7 AGS
Old Jun 12, 2005 | 12:58 PM
conechaser05's Avatar
conechaser05
the install is a pain in the neck to do, but its well worth it. the car sounds great, but not only does it sound great, it is more resposive, power delivery feels more linear and the butt dyno notices a difference also. the only problem is, i have a vacuum leak at the connection between the AGS tube and the supercharger and the car is now lit up with "Service Engine Soon" and "EML" i can do pics/vids/sound later if anyone is really interested
newley changed ags tube has fixed the problem and it runs like a charm. EML light is off, but SES is still on.. maybe with time it will disapear?
Old Jun 12, 2005 | 01:30 PM
haulinS's Avatar
haulinS
any pics, vids, etc on the install, sound, likes, and dislikes about the AGS would be appreciated.
Old Jun 12, 2005 | 04:44 PM
jlm's Avatar
jlm
in my opinion, that joint is ill-conceived on mini's part. I had inquired whether the ags improved on, or at least retained the bracket holding the TB to the engine, as that is 1/2 of the retention system.
Old Jun 12, 2005 | 04:54 PM
M7's Avatar
M7
We have been working feverishly to solve the SC to tube interface and I will test the latest uppdate in the morning. If it works as I hope I will post a how to right away, and this will be a fix that could be done on the spot
Back to the family....
peter
Old Jun 12, 2005 | 06:08 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
glad you are happy with it. Congrats on getting through the install
Old Jun 12, 2005 | 06:54 PM
TheBlackBrian's Avatar
TheBlackBrian
How do you know if you have a leak at the supercharger?
Old Jun 12, 2005 | 09:10 PM
conechaser05
agreed, it absolutely sucks. the bracket would have been good to reuse
Old Jun 12, 2005 | 09:13 PM
conechaser05
peter
phew i dont want to have to take the bumper assembly apart again look forward to the post
Old Jun 12, 2005 | 09:16 PM
conechaser05
its quite obvious... the noise is there, my friend and i doing the install loosened everything enough to move the tube around while the car was running and found a spot where there was no more leak but unfortunately the lame stock bolt couldnt sustain it
any ideas on the EML light anyone? all electrical connections seem to be secure...
Old Jun 12, 2005 | 10:03 PM
TheBlackBrian
So when I get my AGS, am I going to have to mess with it until it fits?
Old Jun 12, 2005 | 11:02 PM
M7's Avatar
M7
We have found that's there's some small variations in the geometry from car to car when you install the AGS. The problem lies in the SC gasket and the floating design that will allow some movements in the tube. I have personally installed many of these systems on multiple cars, some leak and some don't.
With that said I have looked at some small geometry changes, we are only looking at less then 1/4" which we will very easily be changed, thank God for plastics
peter
Team M7
Old Jun 13, 2005 | 02:47 AM
uae mini's Avatar
uae mini
Who is this Good guy? and did he invent plastic?
With that said I have looked at some small geometry changes, we are only looking at less then 1/4" which we will very easily be changed, thank Good for plastics
peter
Team M7
Old Jun 13, 2005 | 07:39 AM
conechaser05
peter do you have any ideas on what would be causing the EML light to be on?
Old Jun 13, 2005 | 08:01 AM
Cooper_Si's Avatar
Cooper_Si
any air leaks after the throttle body will cause poor running which means the EML will come on
so until you rectify the air leak with the AGS pipe, it wont go off.
Try moving the pipe around a little (not in a way to damage it)...as i had the same problem and moving the pipe around fixed the fault, and the car has been fine ever since
Old Jun 13, 2005 | 08:25 AM
norm03s's Avatar
norm03s
Read and post the codes from ECU
As Cooper_Si said, " any air leaks after the throttle body will cause poor running which means the EML will come on "
More air is entering the engine than the air flow sensor is seeing, you are probably running in a lean condition. This could possibly cook the CAT.
Old Jun 13, 2005 | 10:52 AM
conechaser05
that is what i assumed but the owners manual said EML is in reference to an electronics malfunction. also the service engine soon light is on, which i think is also due to the vacuum leak causing a difference in unmetered intake air making it through to the exhaust
Old Jun 13, 2005 | 08:22 PM
M7's Avatar
M7
After hours of testing,the solution is a simple geometry change of the AGS
allowing a 100% seal of the AGS to the SC All the tubes shipping will have the new "fix". If you feel that you have some questions or concernes about
the AGS......Call me:smile:
peter
Team M7
562-608-8123
Old Jun 13, 2005 | 08:35 PM
conechaser05
peter
Team M7
562-608-8123
peter has been more than helpful through the last couple days, so an M7 pulley is going on my car in the next couple days also
Old Jun 17, 2005 | 09:17 AM
conechaser05
all lights are off, the car feels great, no vacuum leak. now its time to put the pulley on
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
