Drivetrain 15 vs 17 vs 19 with JCW intake and injectors
Old May 25, 2005 | 07:32 PM
SpiderKnight's Avatar
SpiderKnight
Hi All,
I have done a lot of research into many different threads concerning pulley upgrades. However, I would still like to hear from all of you concerning similar mods to the ones below:
1. 15 with ECU and injectors CAI exhaust (injectors necessary? I've read somewhere that injectors with 15% helps, after all, JCW does it.)
2. 17 ECU injectors CAI exhaust (GIAC ECU mod good?)
3. 19 " (GIAC IS good, what about SC redline?)
My rig has JCW intake and injectors. I want to do a pulley, hence the thread. I like 15 but this may have made the injector upgrade unnecessary.
17 sounds like injectors are necessary, but not a whole lot of info about this mod with GIAC ecu.
19 and injectors GIAC is much talked about and gets glowing reviews. I am a little concerned about SC redline, so if ya'll can post how long ya'll runnin? Any other problems with 19? Heard a little about pinging.
HOW BOUT THIS NICE WEATHER IN CALIFORNIA?
Old May 26, 2005 | 07:39 AM
hornguys's Avatar
hornguys
I had 18,000 miles on the 15, and have put another 29,000 on the 19. No problems. I use M7 injectors on the 19, stock injectors were on the 15.
Have used Webb/Powerchip ECU for 40,000 miles. Probably go to Unichip for a custom dyno tune like SpyderX did.
I do change belts every 10k or so with the 19, because I'm compulsive...
I arbitrarily use 6500 as a self-imposed redline.
Old May 26, 2005 | 01:26 PM
SpiderKnight
Have used Webb/Powerchip ECU for 40,000 miles. Probably go to Unichip for a custom dyno tune like Spyder-x did.
Thanks for the info.
Did you hear somewhere that you needed to change the belts so often?
Old May 26, 2005 | 01:34 PM
hornguys's Avatar
hornguys
Can't recall a specific recommendation re changing belts.
Just thought it'd be safer since there have been some documented belt issues on tracked cars. I do compete in auto-x in my car, plus occasional track days, so it gets pushed a bit, not to mention my street/hwy behavior...
Old May 26, 2005 | 01:41 PM
SpiderKnight
Cool.
What rpm do you rev to when you "jump on it"?
Old May 26, 2005 | 01:44 PM
hornguys's Avatar
hornguys
As I mentioned, I use a self-imposed redline of 6500. The Webb will go to 7200, however.
Old May 26, 2005 | 01:53 PM
SpiderKnight
Heh, sorry I missed that. I read the text from email and that part was below the screen.
iggi
18
Feb 9, 2026 01:00 AM
bobbiemartin
Jan 20, 2016 05:28 PM
David.R53
Sep 1, 2015 06:49 PM
The_Kid
Aug 28, 2015 04:50 AM
