Drivetrain mesh in hood scoop?
mesh in hood scoop?
Hi everyone,
I live in an area with lots of construction, which will probably continue for several years. This means lots of dirt, gravel, chunks of asphalt, etc. I'm looking at a chrome cover for my hood scoop that includes some aluminum mesh inside the scoop to keep debris out. Would this be a good idea, or would it restrict airflow too much? My engine is stock, but I was thinking of combining the mesh with an Alta diverter in the hopes that they would cancel each other out and prevent harm to the engine. You know, Alta increases airflow efficiency and mesh slightly decreases, so we're back to stock levels. What do you think? Keep in mind that both highways that I drive will have several construction sites along their length, so there will be lots of debris out there. (I'm already considering the 3M shield to protect my paint.)
Air flow restriction will not be an issue. Save your money and just buy some stainless steel gutter mesh from Home Depot. You just trim it with tin snips and install it. Looks good and costs less that $3 bucks and a half hour of time.
Check this link for an excellent how-to
http://www.tech-esq.com/MINI/how_to_...oop_grille.htm
Sean
Sean
Thanks for the tip! I think I'm going to try it. A new intercooler sounds pricey and I don't know if it would be covered under warranty, or decide to give up the ghost the day after my warranty expires. A screen seems like cheap insurance, as long as it doesn't harm anything. Now if the mesh does restrict airflow, I'll notice the water temperature running hotter than usual, right?
I have no idea how sesitive your water temp guage is...That said I would think you would at least have to cut airflow from the Scoop nearly in half before you would see a sizeable difference in your water temp. Maybe someone else could chime in on this.
If I had to guestimate data on how much the grill would decrease airflow, I would say somewhere in the neighborhood of 2% or less.
Originally Posted by andy@ross-tech.com
Water temp is not an indicator of air temp. Checking the intercooler efficiency with a pair of inexpensive temp probes would show whether the mesh causes problems or not.
Sean
Sean
Here's my scoop grille.
Colt45Magnus
Oct 1, 2015 04:08 PM
