Drivetrain Exhaust problem help
Old May 8, 2005 | 07:18 PM
CustomAV's Avatar
CustomAV
I could use any help on this one.
I was at the Dragon this weekend (what a blast!) when last night I noticed the exhaust sounding really rough. It sounded louder than normal (I know some of you would welcome this as would I but not in this case) with a constant fluttering.
Mine is an '05 with factory exhaust. What could be causing this. Someone was wondering if I could be miss-firing and have a bad plug. I was running the car really hard that day on the dragon (as I should be).
This morning when I cranked the car up it sounded just fine. When we got to a stop for lunch it was doing it again.
So basically what I have is a lower tone in the exhaust with a constant fluttering sound.
The car idles fine and I don't seem to have any performance problems.
I do have a SES with code 1498 but that has been there since last weekend when I installed the AGS and I was not going to deal with that until I got back from the dragon since I didn't want to risk screwing something up when I took apart the car again.
Any help you can offer would be appreciated.
Chris
Old Dec 2, 2006 | 07:10 PM
vlkwagen's Avatar
vlkwagen
Any news on the 1498 code?
I just had my codes read and I am throwing a 1498 code
I have also installed the AGS on my car, but I have no idea what the 1498 code is as it is not in the back of the 2004 service manual
My car is a 2006 and I also have the SES light on and I have the EML light on and my car is hunting for idle and is hunting under load
Any ideas?
Anthony
Old Dec 2, 2006 | 10:04 PM
minimc's Avatar
minimc
Chris
It might seem obvious, but did you crawl under there and check the gasket between the exhaust manifold & cat-back? One or both of the studs could be loose, creating a gap, and causing the noise.
The system expands considerably when hot, then contracts back when cold... which would explain why it sounded fine in the morning.
Svejk
Feb 24, 2019 12:18 PM
alistaircookie
Oct 8, 2015 10:52 AM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
