Drivetrain JCW Exhaust..new rattle
Old Apr 29, 2005 | 05:10 PM
CARdiac's Avatar
CARdiac
I have 2500+ on the odo and today the exhaust started to rattle...anyone else have this problem?
Old Apr 29, 2005 | 05:45 PM
camelpilot's Avatar
camelpilot
where does the rattle come from? It's probably your resonator...... you know what that means right? ... Time to chop that mother out and hear the pain.
Old Apr 29, 2005 | 10:59 PM
MyPocketRocket's Avatar
MyPocketRocket
When do you hear the rattle? Can you hear it all the time or just when taking off?
Old Apr 30, 2005 | 06:38 AM
CARdiac's Avatar
CARdiac
I hear it under acceleration
Old Apr 30, 2005 | 07:03 AM
uae mini's Avatar
uae mini
Probably the heat sheild.
Mine rattles at idle.. Its fitted new though.
Old Apr 30, 2005 | 07:13 AM
camelpilot's Avatar
camelpilot
If you can, get under the car and check a couple of places.
1.) Check the metal plate between the 2 mufflers. Make sure it's not close to the exhaust pipes towards the tip side. If it is, you need to bend it so that it's not too close, or it will touch during driving.
2.) Check the thin metal heat shield above the exhaust system. It's the thick metal foil looking stuff.. make sure thats not touching the pipes, especially at the part where the straight pipe connects to the y piece.
3.) Bang on the resonator with the soft part of a closed fist (the bottom). If you hear a little rattle like a small piece of metal is floating around in there, then you have a bad resonator (which will rattle), which is a good thing, because you dont need that silly rez anyway. Just get it removed.
Old Apr 30, 2005 | 08:11 AM
CARdiac's Avatar
CARdiac
Sorry for my ignorance... where is the resonator?
Old Apr 30, 2005 | 09:27 AM
camelpilot's Avatar
camelpilot
It's near the engine, under the car, round, cylindrical, bout a foot long, cant miss it. Probably directly below your stick shift.
Edited: Found a pic of it. It's the cylindrical thing on this pipe.
Old Apr 30, 2005 | 11:40 AM
kenchan's Avatar
kenchan
don't bang on it with your bare fist if your car is warm/hot.
(dumb advise, but ive known people grabbing the pipe right after
a run and learn quickly they get pretty sizzlin' hot).
Old Apr 30, 2005 | 01:04 PM
CARdiac's Avatar
CARdiac
Thanx for the advice ...
woodstudio
Mar 15, 2020 08:28 AM
TREX
Nov 2, 2019 07:31 PM
MiniJess
Detailing 101
30
Aug 4, 2016 03:43 PM
alistaircookie
Oct 8, 2015 10:52 AM
iclancy82
Aug 11, 2015 09:35 AM
