Drivetrain The Best Performance Mod so far...No not Viagra.
Old Dec 29, 2002 | 06:17 PM
  #26
MINIclo's Avatar
MINIclo
7th Gear Gal
So, guys! Hiya! Um, I don't know much about mods, but I like dpayne1's fat tyres!!! I have the standard 15" holeys...will the fatties work on MINIclo, too?
Cheers!
Clover
Old Dec 29, 2002 | 08:17 PM
  #27
dave's Avatar
dave
pug poo picker-upper
Clover: since dpayne1 is using these as autocross tires, there shouldn't be any problems with having them fit the stock wheels (since that would be one of the requirements in SCCA autocross).
With that out of the way, the question to ask yourself is which you place priority on when looking for a tire? Looks? Adhesion? Low tire noise? Durability? You can't have all of those at once.
Actually, I bet if you start a thread in the Tire and Wheel Forum many people more knowledgeable than I would be willing to help you sort this out.
Old Dec 29, 2002 | 08:59 PM
  #28
dave's Avatar
dave
dpayne1: what size are you running the Kumho Ecsta 712s in 15"? 205/55-15?
Old Dec 30, 2002 | 03:49 AM
  #29
dpayne1's Avatar
dpayne1
Dave
225/50/15 BF Goodrich g-force TA KD tires are on the 15" wheels, the Kumho Ecsta 712s are my street tires - (215/45/17).
BTW, I have a set of the 16" X lites (Stock MCS Wheels) w/ the Kumho V700 R compound tires (205/45/16) - I used these twice last year for autox events - they are legal for DS (Now GS) -- They are for sale if anyone's interested.
Old Jan 9, 2003 | 08:04 PM
  #30
ficcion's Avatar
ficcion
Randy and I put my wheel/tire set up on his car with the H&R springs.
We got slight areas of "rubbing" on the back wheel wells upon signifigant compression of the springs ( hard cornering on uneven surfaces ).
We think there is a possiblity of a small mod to "recontour" the plastic under the wheel well to avoid the rubbing altogether.
The wheels look MUCH BETTER on the lowered car with the H&R springs. Probably the best look I have EVER SEEN on a MINI to date!! (Sorry didn't have a camera at the time.) :smile:
Old Jan 9, 2003 | 08:31 PM
  #31
dave's Avatar
dave
ficcion: are you interested in a set of H&R springs?
Old Jan 9, 2003 | 08:35 PM
  #32
Karol's Avatar
Karol
ficcion,
Can you post some pics of this set up?
Old Jan 10, 2003 | 04:19 PM
  #33
ficcion's Avatar
ficcion
Sorry, we have already put the wheels back on my car.
You can get an idea in your minds eye if you just delete that space between the top of the tire and the wheel well :smile: ...think much meaner, more aggressive stance.
Old Jan 11, 2003 | 10:21 AM
  #34
friedduck's Avatar
friedduck
Photoshop lowering job here <grin>
Jeff
Old Jan 11, 2003 | 02:27 PM
  #35
ficcion's Avatar
ficcion
>>Jeff
Very nice job Jeff! Looks very real. :smile:
The H&R's tend to drop the backof the car even a bit more so the front to back stance is flatter unlike the stock springs"butt in the air thing".
Old Jan 11, 2003 | 03:08 PM
  #36
LifeIsGood's Avatar
LifeIsGood
Just a clarification...when you say wheel well, are you referring to the inside of the wheel well or the outside near the plastic fender? If it is the inside, would small spacers help?
Thanks for checking that out.
Old Jan 11, 2003 | 04:45 PM
  #37
ficcion's Avatar
ficcion
Right on the "internal edge" of the "outside plastic fender" is where it is rubbing.
A spacer would only increase the rub in this senario. :smile:
_________________
<IMG SRC=https://www.northamericanmotoring.com/albums/album04/bvr.thumb.jpg>
Borla Exhaust,
Madness Intake,
Rota Circuit 8 wheels,
Falken Azenis Sport
Old Jan 11, 2003 | 08:11 PM
  #38
LifeIsGood's Avatar
LifeIsGood
Gotcha. Now the question that needs (I need) to be answered, then, is will the 8 mm offset difference between the wheels that you have (40mm offset) versus the stock R84's offset (48mm) make a difference.
I would rather have a little rubbing on the outside where you are experiencing it than on the inside of the wheel well. Seems like the lip of the plastic fender could easily be "modified" (cut away or ground down) without much, if any, visual indication that it had been modified.
Thanks again for your work and comments.
Old Jan 11, 2003 | 08:12 PM
  #39
LifeIsGood's Avatar
LifeIsGood
A little more negatinve camber would fix the problem as well if additional negative camber is possible with the lowered car.
Old Jan 11, 2003 | 09:09 PM
  #40
ficcion's Avatar
ficcion
The stock 48mm offset (16" and 17" wheels) fits just fine with no rubbing. We have tried it with the H&R springs because DaveinDenver and Randy run both those combos. They are running 205's but I don't think 215's would matter with stock offset.
I think a 45mm or possibly a 43mm offset would work fine too, all other factors being the same. It is that close!
As to more negative camber in the rear...well we have too much already due to the lowering springs. Negative camber in the rear is not welcome when it comes to handling better. I would look at making a mod to the fender plastic before increasing the negative camber.
Now if that negative camber could just be on the front wheels!!!
Old Jan 11, 2003 | 09:14 PM
  #41
dave's Avatar
dave
This is part of the reason I would like to get coilovers, so that I can raise the back end (vs. the 1" drop of the H&R springs). I'd like to get 3/4" drop in the rear and an inch to 1 1/4" in the front.
Old Jan 21, 2003 | 12:06 PM
  #42
kite-surfer's Avatar
kite-surfer
Dumb question but the stock 17 with run flats are about 47 pounds how much would some ssr 17 with tires weigh? Ruff guess since each tire is going to be different.
Old Jan 21, 2003 | 02:23 PM
  #43
ficcion's Avatar
ficcion
Here is a great chart on wheel weights: CHART
SSR 17" will be about 12.7 lbs. A 17" tire will weigh more (generally speaking) than a 16" so lets say 22-23lbs.
A total weight of 34.7-35.7 lbs. per corner. And don't FORGET...a severe drain on the checkbook for the SSR's and the larger sized tire.
Aug 25, 2015 07:11 AM
3MCS1DJ
Aug 23, 2015 02:08 PM
Aug 21, 2015 11:25 AM
minipopkart
Aug 13, 2015 05:22 AM
