Drivetrain Help me with mth!!!!
Old Jan 21, 2005 | 12:09 PM
Aliron's Avatar
Aliron
I have follow all the instructions but when i press the id button i get:
echo missing. adapter available??
what i´m doing wrong? I have set the port at the same number at the laptop and the cartune, set the speed to 115200 and closed all the apps...
Any comments??
Old Jan 21, 2005 | 01:29 PM
Aliron's Avatar
Aliron
please help!!!
Old Jan 21, 2005 | 01:36 PM
dhayashi's Avatar
dhayashi
some times you need to change the port number in the mth software.
ex. Port 1 > port 5 then change back and try to refresh.
Also make sure your using the right com port. I also would try going into the advance properties of the COM and lower your FIFO speeds to increase your ability to sync properly.
good luck
Old Jan 21, 2005 | 01:43 PM
Aliron's Avatar
Aliron
thanks!! what are the fifo speeds? i´m running spanish xp and it will have an other name. Which figures yo recommend my to set?
Mark
MTH Discussion (Archive)
653
Dec 5, 2005 03:18 PM
BluMiniMe
Apr 24, 2005 11:02 PM
johnD
Oct 13, 2004 07:00 AM
