Drivetrain N18 S turbo upgrade - exhaust manifold Q
Old Oct 3, 2020 | 06:25 AM
HHMCS's Avatar
HHMCS
Hi all, as above I'm looking to upgrade my Cooper S turbo. Do I need to bother with changing the manifold? Seen misleading info as to whether the JCW is worth it, especially N14 ones which are more easily available.
Not chasing huge numbers, a solid 240whp would do me fine.
Cheers...
Old Oct 3, 2020 | 12:15 PM
Project_Mini's Avatar
Project_Mini
I have a a JCW turbo on my 09 MCS with the OEM manifold. I would think you need to go bigger for 280 whp though.
I have an RPM stage 3 tune and was told about 250 whp has been seen.
Old Oct 3, 2020 | 12:29 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I bet you’d see better advantage from port matching the manifold to the head, and port matching to the turbine housing. Nothing magical in the “JCW” manifold compared to the Cooper S manifold.
Old Oct 3, 2020 | 12:54 PM
HHMCS's Avatar
HHMCS
Aw damn, sorry - 280bhp, so more like 240 whp. Will edit the OP.
Thanks though, seems like should get there comfortably in stock manifold
Old Oct 3, 2020 | 01:06 PM
Project_Mini
then you should get that. But you need stage 3 supporting mods. I saw a post on either this site or on Facebook where a guy dyno’d right around 245 whp with a jcw turbo and basically the same mods i have and same RPM stage 3 tune
Old Oct 3, 2020 | 02:07 PM
HHMCS's Avatar
HHMCS
then you should get that. But you need stage 3 supporting mods. I saw a post on either this site or on Facebook where a guy dyno’d right around 245 who with a jcw turbo and basically the same mods i have and same RPM stage 3 tune
Upgraded the exhaust, IC, flywheel and clutch so hopefully good to go once decided on turbo and tune. Cheers for your help 👍
minimesd
Oct 1, 2020 09:43 AM
ludrof11
Mar 3, 2018 03:18 PM
Drexial
Mar 7, 2016 06:15 PM
joey1320
Jul 30, 2013 10:09 PM
joey1320
Apr 1, 2013 10:15 PM
