Drivetrain A close shave
Old Dec 16, 2004 | 07:06 PM
Helix13mini's Avatar
Helix13mini
A close shave
Had a fun one today. I did a cam on a Cooper: my first on the NA car. When I was placing the Schrick in the journals, on a lark, I spun it half-consciously before re-assembling the rocker train. To my amazement, the higher exhaust lobe for cylinder number 1 was hitting the coolant plug in the bowl of the head. There was probably 2mm of interference. What a pisser. Had I just reassebled the car as usual, there would have been some nasty smashing of bits the valve train.
The problem was easily solved. I consulted JLM, and just removed the plug, cleaned up the threads, and put new silicone sealant on it. about two more turns into the bore and presto, no interference. Well, almost no interference. Turns out that another lobe just barely touched one of the spark plug tubes. Nothing a careful whack from a hammer can't solve. Yup, that's helix workmanship: done with a hammer.
The moral of the story is if any of you Cooper folks are doing a cam on your car, give it a spin to make sure you don't scattervalvone (a common Italian malady) all over the inside of your motor.
Old Dec 16, 2004 | 07:19 PM
Ryephile's Avatar
Ryephile
I've done several Camshaft installs - no coolant plug interference yet, but on every one I've had to flat-spot the spark-plug tubes, as they were interfering with the higher lift exhaust lobes.
Old Dec 16, 2004 | 07:47 PM
jlm's Avatar
jlm
We did have a scary clattering problem after fitting a cam, but it was just the chain tensioner taking its time to pump up.
when assembling engine components we are always close to the jar of moly assembly lube.
Old Dec 16, 2004 | 08:03 PM
Ryephile's Avatar
Ryephile
Moly lube, while essential for assembly, doesn't get rid of interference
Old Dec 16, 2004 | 08:17 PM
minimc's Avatar
minimc
...What? ...you mean its not like KY for engine parts?
Old Dec 16, 2004 | 08:50 PM
Ryephile's Avatar
Ryephile
well it is - but you still can't go putting things where there's no provision for it
Old Dec 16, 2004 | 08:57 PM
SwingMCS03's Avatar
SwingMCS03
Wallace and Gromit
Old Dec 16, 2004 | 09:08 PM
fishey72's Avatar
fishey72
I always love to hear "bigger" hammer solutions
Old Dec 17, 2004 | 04:09 AM
jlm's Avatar
jlm
thought we would just add another cam install tip. no other logical connection intended.
Old Dec 17, 2004 | 06:30 AM
Helix13mini
I've done several on MCSs, with no Interference from the spark plug tubes. Wierd. Did you install Schrick cams? I wonder if there is that much manufacture variation from the Brazilians (maybe only the Monday mornings after Ronaldo connects with Cafu for four goals).
Old Dec 17, 2004 | 07:44 AM
jlm's Avatar
jlm
or too many caiparinas on the beach
Old Dec 17, 2004 | 08:59 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Old Dec 17, 2004 | 09:05 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
yeah eric,
both cams we got from you. one was cooper, one was cooper s, and both had to have flat spots done in the spark plug tubes. everything was golden after a bit of tapping.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 17, 2004 | 09:06 AM
Ryephile's Avatar
Ryephile
Yes Schrick cams. Interference that would hinder rotation on at least one tube every time. The other tubes may range from a brush against to barely clearing. I'd guess the tube install tolerances are about as accurate as their installation (which is with a hammer)
Old Dec 17, 2004 | 09:39 AM
Helix13mini
Originally Posted by SwingMCS03
Wallace and Gromit
I do like a bit of Gorgonzola
Old Dec 17, 2004 | 09:48 AM
Maximusmini's Avatar
Maximusmini
Hey, thats my car you're talking about! Oh Well, No big deal. But hey! It rocks! for a CVT Cooper, now, my plans are mixed. I really do want a Cooper S, but then I have this ticking idea in my head. I'm not giving this one away unless Misfitoy gets to my thought proccesses again.
monkiboy
Oct 16, 2015 09:58 AM
pkillur
Sep 30, 2015 10:51 AM
Emnotek
Sep 29, 2015 07:37 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
