Drivetrain RMW Shorty Header - Broken flex pipe
Old Dec 16, 2019 | 10:34 AM
Soul Coughing's Avatar
Soul Coughing
Hey Everyone,
I've been hearing a slight exhaust leak, which has progressively gotten louder each morning when i start the car up. I was able to quickly jack it up and diagnose it as a flex pipe crack. I can cut out and replace the old flex pipe, but I just haven't been able to completely measure it up and wondered if anyone knew the sizing of the flex pipe and if anyone had a well built one I could order in advance of pulling it all apart. Any input would be appreciated! Thanks
Old Dec 16, 2019 | 11:52 AM
BlwnAway's Avatar
BlwnAway
Unfortunately I can't give you any actual specs, but it should be a 2½" diameter, get a hold of RMW they should be able to help you there.
Did you replace/upgrade your upper motor mount before or when you installed the Header?
The factory motor mounts amount of movement is the normal cause for the flex basket to fail on those headers.
Unfortunately, more times than not, the mount change is perceived as being known and understood, not necessarily advertised as being needed with install.
Old Dec 16, 2019 | 12:24 PM
Soul Coughing
Thanks for the response. Yeah, I changed every mount when i rebuilt the car. It has the powerflex inserts as well, so the motor flex is minimal. When i got underneath the car, with the engine running, to find the leak, I could see the harmonic resonance vibrating the flex pipe, so it makes sense that it broke.
Old Jul 6, 2022 | 01:30 PM
The Devil Z's Avatar
The Devil Z
Bump does anyone know the spec on the flex basket used on RMW shorty? Assume its a Vibrant? Need mine repaired and wanted to hopefully source a good one before crawling under there and taking measurements and or removing header.
Old Jul 7, 2022 | 10:44 AM
Soul Coughing
I bought a bunch of different flex pipes, and used the one that fit most closely. I ended up putting it on and having the flex pipe fail again, so I've been running the stock header. If you do ever work out what one it is, let me know as I miss my RMW header on my GP!
Old Jul 11, 2022 | 08:41 AM
The Devil Z
Vibrant interlock style turbo/FI 2.5 x 4"
https://vibrantperformance.com/turbo...k-liner-v1182/
jfrankjr
Oct 16, 2018 05:49 PM
Yupoong
Jul 31, 2017 10:05 AM
Piano Man
25
Jun 15, 2015 06:00 AM
csgirardeau
Apr 16, 2014 09:46 AM
jibeho
Dec 20, 2007 07:35 AM
