Drivetrain BOOST LOSS NEED HELP!!!!!!! Runing 19% pulley
Old Mar 11, 2005 | 04:13 AM
  #26
uae mini's Avatar
uae mini
hmm..
Can't we just replace the stock one out with a better quality aftermarket peice?
Old Mar 11, 2005 | 07:22 AM
  #27
BlueMCS's Avatar
BlueMCS
Originally Posted by MiniPilo
Not sure.. just started getting 2.5 lbs boost...
Boost Loss?
Old Mar 11, 2005 | 07:59 AM
  #28
Ryephile's Avatar
Ryephile
Originally Posted by uae mini
hmm..
The Stock BPV design is reasonably good. As long as it was assembled correctly and all parts are complete, it'll last a long time. The only aftermarket piece that I've heard of is one that is still based on stock, but uses a metal diaphram assembly bolted to the stock butterfly housing....for a huge amount of money.
Old Mar 11, 2005 | 08:02 AM
  #29
dominicminicoopers's Avatar
dominicminicoopers
To replace the bypass valve, couldn't we use something like a blow-off valve in it's place?
Old Mar 11, 2005 | 09:18 AM
  #30
jlm's Avatar
jlm
the point of the bypass valve is not to limit boost (like a blowoff valve) but to re-direct it under non-load situations (equated with a vacuum condition upstream of the blower intake, downstream of the throttle body), moderated by the spring
Old Mar 11, 2005 | 09:24 AM
  #31
andy@ross-tech.com's Avatar
andy@ross-tech.com
Sounds like this thread:
https://www.northamericanmotoring.co...ad.php?t=35816
Old Mar 11, 2005 | 09:25 AM
  #32
dominicminicoopers
Whoops after drawing a diagram of this on a napkin, I think I've got it
Last edited by dominicminicoopers; Mar 11, 2005 at 09:37 AM. Reason: figured it out...
Old Mar 11, 2005 | 09:38 AM
  #33
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by dominicminicoopers
A couple of follow up Qs....because I guess I don't understand...
Does the compressed air really need to be redirected? Can't it just vent to atmosphere?
what up DOM!! I have researched this...it's is ofcourse possible...it would not hurt the car...since it is not designed that way some do not like the Idea...but if you want that...you know who to call...I am going to be doing some with him anyway...heh eh...maybe we can do something in the mean time...
Old Mar 11, 2005 | 09:50 AM
  #34
dominicminicoopers
Tuls, I think what jlm said makes sense to me now. I diagramed it out on a napkin and figured out this: A blow-off valve opens up when a preset boost pressure is reached. However, with the MCS's SC bypass valve, it stays closed during pressurized (boost) and will open up when low or negative pressure (vacuum) is detected.
Old Mar 11, 2005 | 09:51 AM
  #35
MiniPilo's Avatar
MiniPilo
JLM,
Your thinking of the waste gate. That limits boost. The BOV releases boost either into the atmosphere, or back into the intake track (like our Bypas) to allow the turbo to keep spinning when the gas pedel is released, like during a shift ect. This allows one to get boost faster during shifts, instead of the turbo stopping because the air has no where to go.
BernieCoop
Sep 10, 2021 03:15 AM
paul7878
Sep 14, 2015 07:44 AM
Mb460
Sep 14, 2015 05:50 AM
Emnotek
Sep 11, 2015 04:16 PM
mbatech
Sep 10, 2015 03:40 PM
