Drivetrain Turbo install kit discussion
Old May 14, 2019 | 01:02 PM
I_Forge_KC's Avatar
I_Forge_KC
I'm gearing up to install a complete exhaust from the head back. I know it's smart to swap out the oil lines with new and refresh all the hardware, but there are several different options and I'm looking for a discussion on what's everyone's favorite approach.
Some examples...
WMW
https://www.waymotorworks.com/turboc...8-r59-r60.html
ECS
https://www.ecstuning.com/b-assemble...53039880146kt/
MM
https://new.minimania.com/part/G2NMK...m-Gen2-R55-r61
OM
https://www.outmotoring.com/turbo-oi...grade-kit.html
DT
https://www.detroittuned.com/dt-turb...ine-super-kit/
To me, it looks like there are a few different stainless lines for the oil but I struggle to understand the wild price differences in some of these. Now, I obviously realize that the different kits come with different stuff (though most are configurable/comparable). Can anyone share their experience/opinions?
Thanks.
Old May 15, 2019 | 04:53 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
The DT kit is still the best and most complete kit out there for solving the leaks. These are the leaks we see all the time in the shop since we are more than just a web store. Some of the other kits, while will work, but come with some parts you do not need for what you're about to do and are not needed or will not have all the parts you need to finish off what you are trying to do. Also, we are the originator of the turbo oil line and almost everyone above bought it from us at one point. I would also never use the OEM Turbo Oil Line in any type of rebuild. Let me know if you need any help.
Chad
DT
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old May 20, 2019 | 05:08 PM
E34M5's Avatar
E34M5
I will never again run my line the factory route. Last track day the turbo got very hot and melted the line inside the metal braided jacket. I was very fortunate it did not seize up or damage my motor. Went to local parts store and was able to find all the banjo bolt fittings and a longer line to reroute it over the top of the turbo and around underneath to avoid running directly behind the housing. Take the time and do it this way to avoid any possible catastrophic failure. Please note the melted valve cover, also a known issue with these cars, have to add additional heat shielding
gimmea250swb
Apr 9, 2018 05:41 PM
JCWCabrio
21
Jun 1, 2016 09:17 PM
Sean Pine
Massachusetts Motoring Club
Sep 2, 2015 08:16 PM
bmwbrandon
Mar 8, 2013 07:48 PM
SlowB00st
Feb 26, 2009 12:32 PM
