Drivetrain sc maintenance
sc maintenance
I've decided to go ahead and order the maintenance kit for the supercharger since its never been done and I'm in service mode now. should I go ahead and replace the water pump while I'm at it as a preventive or leave it alone if it hasn't failed?
Since you have to pull it off anyway it's what we do when we do a service.
Here is our kit
https://www.waymotorworks.com/superc...t-r52-r53.html
and the water pump to add on
https://www.waymotorworks.com/r53-water-pump.html
Here is our kit
Of course you can physically put more in than is recommended but you shouldn't. There are very specific recommendations for the quantity of s/c oil to put in, and it is different for each end.
I know there was recommended about and the kit I received from WMW had two bottles so when I did it I stood each side upright and filled, then leveled SC without plug if nothing drained I repeated process until fluid trickled out, then capped.
