Drivetrain new belt tensioner/idler
Old May 13, 2005 | 04:51 PM
  #51
JeffS's Avatar
JeffS
Six months later...
maybe this should be moved over to the vaporware forum
Old May 13, 2005 | 11:34 PM
  #52
XTREEM's Avatar
XTREEM
Originally Posted by JeffS
Six months later...
Is that where the M7 AGS Dyno numbers are stored?????????????????????
Old May 14, 2005 | 05:52 AM
  #53
XTREEM's Avatar
XTREEM
Originally Posted by jlm
let me communicate some tidbits:
in the stock system:
-weak link 1: the idler pulley needs a proper standoff/boss and washer; this is a $5 part, even though custom made;
-weak link 2: there is a too-long bolt attaching the motor mount bracket to the block surface right above the tensioner bracket. the too-long portion is an un-threaded pilot, completely un-necessary. the bolt should be removed and the pilot cut off. It is possible that too much beef applied to the tensioner tool can force the back of the tensioer bracket into this pilot, with the result that the bracket can be nicked and break (this is EXACTLY where the broken ones have cracked);
-weak link 3: the pulleys and bearings are well made, although they should all be trued; a fairly simple machining operation, where the pulley is spun on its bearing axis and the surface skim cut, removing no more than .005"
-weak link 4: if the pulley diameter is reduced, the spring pressure will be lessened; a spacer is required under the spring for reduced pulleys sizes;
weak link 5: should the belt snap, the only thing keeping the tensioner assembly from extending into the crank pulley and destroying it is the wimpy metal strip. this needs improvement. (Roland simply added an extra metal strip next to the dampener to control this, but that is less than ideal)
sufficent in the stock system:
-the bracket itself is strong enough and reasonably unstressed as the spring force is directed right at the tensioner pulley, (as long as one doesn't mash the bracket into the too-long bolt by leaning on the tensioner tool).
-pulleys and bearings;
-dampener; they may fail, but the unit seems adequate.
Jlm, Do you replace the spring strap (piece with the T)??? For something more substantial?
What size spacer would you reccommend behind the spring for a 19% pulley?
The Engine mount bolt was a good find!!!! Thanks.
Old May 14, 2005 | 10:06 AM
  #54
Galaxie500's Avatar
Galaxie500
jlm we need this Mod! Know you are busy, but please, please keep working on it and bring it out. I volunteer to be one of the first to try it.
Old May 14, 2005 | 10:09 AM
  #55
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I'm very interested and know several others in Hawaii that are too.
Just waiting to hear from you on any progress made.
Thanks. :smile:
Old May 15, 2005 | 02:53 PM
  #56
spillman's Avatar
spillman
I too am interested in knowing what size spacer should be used on a 19%. If you add a spacer here you would be able to use a belt for much longer... Wouldn't you? Seeing as how this would translate into greater belt tension and more of a margin for the belt to stretch.
Please correct me if I'm wrong.
Old May 15, 2005 | 09:28 PM
  #57
BelowRadar's Avatar
BelowRadar
Product or DIY? You be the judge. I for one hope it's a new product/kit. If it isn't specifically fabricated for its purpose (round peg in the round hole), then I'll eff it up.
Old May 16, 2005 | 01:46 AM
  #58
XTREEM's Avatar
XTREEM
Hi Spillman, I have started doing this project on my own and the most important thing is the idler wheel mount, The mounting is just not good enough, A bush must be turned up that goes both into the block recess and the idler wheel itself, In standard form it is only held in place by the clamping force of the 8mm bolt, I have also started making a tensioner stop which is just a strap on the little shock which takes the tension in the case of a broken belt and stops the tensioner crashing into the crank pulley.
As for the packing of the spring I dont think this is a issue as the spring seems to have plenty of stroke left anyway. I will let you know in a few days how I have gone.
John.
Old Jun 10, 2005 | 05:25 AM
  #59
Stu(pid)'s Avatar
Stu(pid)
Any update on this?
Old Jun 10, 2005 | 05:36 AM
  #60
MiniRiderBill's Avatar
MiniRiderBill
Making a living!
To hell with the living we want parts Gimee, gimee
Old Jun 10, 2005 | 06:36 AM
  #61
minimort's Avatar
minimort
Where has the product gone?
Old Jun 12, 2005 | 04:32 AM
  #62
XTREEM's Avatar
XTREEM
Hey guys I Turned up a bush for the idler wheel, which spigots into the block and idler, pretty simple thing to do once you have removed and measured!!
I also made a stop for the tensioner, which just consists of a Aluminium strap which is mounted on the same mounting points as the little shock, using longer bolts and small spacers so as the aluminium does not get pinched, Its best to remove the spring and re mount the tensioner so you can measure the stroke and make the new aluminium piece to take the tension just before the T piece on the spring retainer would take the force of a broken belt.
A easier option would be making a small stainless steel cable with well crimped ends and mounting it on the shock mount bolts, with a small loop in it, which would extend to the correct lenght in a belt snap situation. Same procedure for figuring out the correct lenght as the other option.
I know this probably wont make sense without pics... but i forgot to take them
Old Jun 12, 2005 | 08:00 AM
  #63
eMINI's Avatar
eMINI
Keep it coming, there's still an interest.
Old Jun 12, 2005 | 06:18 PM
  #64
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
Xtreem,
I was thinking of doing the same thing, it's going to be either a stainless steel plate or a stainbless cable with loops on both ends. I think the plate would be more secure since you don't have to worry about the crimp slipping. My question is do I need to jack the whole engine up to do this or is it doable by just removing the felder liner? This is the only thing holding me back.
John
Old Jun 12, 2005 | 11:39 PM
  #65
XTREEM's Avatar
XTREEM
Originally Posted by johnD
Xtreem,
John
Hi I done mine at the same time as the pulley instalation, so i had the engine jacked up, It is probably possible without it though... Yeah i used the plate myself but next time around I would just use the cable with good quality crimps. The pressure wouldnt be that great on the cable anyway as the spring isnt that compressed and were not talking about a lot of stroke. The key is getting the exact right length.
John.
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
