Drivetrain R56 build recommendations
Old Oct 3, 2018 | 11:10 AM
dspeed22's Avatar
dspeed22
I have an 08 r56 JCW (none jcw engine) that now has a blown motor, timing chain let go. It has been mostly stock with upgraded brakes and has 80K miles on it. I am contemplating doing an a build on this car for street/track. Thinking I may need a new long block but its possible I can rebuild the head and bottom end. Looking for recommendations on performance components for the build. I have looked briefly at ECS tuning's long blocks and Pro-werx performance engines. Will be getting an upgraded turbo and also putting limited slit diff in the trans. I would like to get up to the 400 hp range staying in a budget of 15k or so. I have experience rebuilding and boosting Honda engines but that was about 15 years ago those were easy .
Looking for recommendations for all components.
Will the trans handle 400 hp with after market clutch?
What clutch kit should I use?
What turbo supplier rebuilder is recommended?
What injectors?
Will stock high pressure/low pressure fuel pump handle the fuel demand?
Do I need to get the ecu flashed or is there another tuner replacement ecu? Or is any good recommendations for tuning shops in my area (Seattle)?
Any particular issues that anyone has run into doing something similar?
- Doug
Old Oct 3, 2018 | 11:30 AM
dspeed22's Avatar
dspeed22
oops realized I put this in the gen 1 forum. Moved to 56 forum https://www.northamericanmotoring.co...ml#post4424200
Old Oct 3, 2018 | 01:42 PM
cornjuice's Avatar
cornjuice
From my own research for my build, Ive found:
A=
*trans = yes.. axles.. no
*clutch = OS Geiken or similar stg3+ will suit more tq than the motor will output
*talk to Mario Palza here on the forums (aka mario kart).. upgraded turbine or big turbo setup
*cant change injectors
*stock HPFP will NOT handle more than ~320HP at the crank - replacing the in-tank fuel pump with a high output pump could get you a bit further (safely?)
*RPM power tuning for your ECU needs.. again - Mario is the man
Few other things -
*stock head/valves/cam will hold you back the closer you get to 300whp
*JCW bottom end is good to ~300whp - though many folks approaching that level have replaced the OEM rod bolts for ARP hardware (can be done anytime)
*Methanol injection will be needed as you will run out of fuel otherwise
Old Oct 3, 2018 | 04:47 PM
dspeed22's Avatar
dspeed22
Do you know if there is a difference btw blocks for JCW and S? I am pretty sure I will probably need to to sleeve the block and replace the pistons if I keep the bottom end. Haven't taken it apart yet, but it ran for about 30 secs after the chain broke. Looked in the oil cap and its not good, valves definitely hit the pistons.
Old Oct 4, 2018 | 05:24 AM
The Forged internals, ecu flash, updated intake pipe design, different turbo. Those are some of the main differences. I have an R58 JCW and had an R56 MCS. The later N14 engines from the factory hold up better compared to the earlier ones. Sneed4speed has full built engines that replace the internals and then you could do a JM Turbo Cooper turbo. Some options there. For a clucth, you could do OS Giken. They are the most well known and from looking at the way they are made, pretty nicely built. They have 2 levels.
Form having both an early R56 MCS and the later Germany built JCW engine.The JCW will hold up better from the factory if modded, but if you fully build a MCS engine up it could get to that same level.
jamez
Suspension
11
Apr 11, 2020 04:50 PM
djbrown
Tires, Wheels, & Brakes
21
Jun 26, 2011 10:52 AM
asaulo1
Suspension
Apr 13, 2009 10:17 PM
Motor Head
Suspension
Aug 16, 2008 09:11 AM
