Drivetrain Intercooler boost tube replacement
Old Sep 22, 2018 | 04:03 PM
Velothree's Avatar
Velothree
I have a new intercooler and preparing to install on my N18 2013 MCS and already have a silicone replacement for the hot side to remove the resonator, but also would like to replace the cool side elbows with some silicone replacements in red. Anyone know of any specifically for the N18 engine without the sound generator? Seems all the ones I find both top and bottom (near the IC) are for the N14 engine.
Anyone know the dimensions? Maybe I can order them off siliconeintakes.com.
Old Sep 22, 2018 | 04:44 PM
chrunck's Avatar
chrunck
Are you certain that there's a difference in the boost tubes for the N14 vs N18? I don't know for sure if there is.
Alta sells red tubes. They just say R56 2007+. Maybe give them a call?
https://altaperformance.com/i-14007129-hot-side-boost-tube-for-r56-turbo-engine.html
Old Sep 22, 2018 | 05:05 PM
cornjuice's Avatar
cornjuice
no difference.. and your paying a lot for silicone fittings with no performance gain.. just sayin
Old Sep 22, 2018 | 08:09 PM
Velothree's Avatar
Velothree
https://altaperformance.com/i-140071...bo-engine.html
I already have hot side tube, but looking for the cool or intercooler to intake side tubes in red.
Old Sep 22, 2018 | 08:10 PM
Velothree's Avatar
Velothree
I know no performance benefit, but just looking to match color theme under the hood.
Old Sep 22, 2018 | 08:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes we have the Forge hose for the throttle body hose
https://www.waymotorworks.com/forge-...lete-hose.html
You just don't have a noise maker, but goes in same location.
Old Sep 22, 2018 | 09:09 PM
Velothree's Avatar
Velothree
I'll order one as soon as I depart China and can access your site.
Old Sep 22, 2018 | 09:15 PM
Velothree's Avatar
Velothree
Is there anything for the bottom side?
Old Sep 23, 2018 | 07:37 AM
chrunck's Avatar
chrunck
Oh, duh, I can't read. Good luck in your quest!
Old Sep 23, 2018 | 02:14 PM
WayMotorWorks
Vendor
Yes for the intercooler outlet side
https://www.waymotorworks.com/forge-...rbo-hoses.html
Old Sep 23, 2018 | 02:38 PM
MrGrumpy's Avatar
MrGrumpy
There you go! Way has you covered!
On a side note, I took a look at the link to WMW’s site, those look pretty sharp, and something like the blue set would match my hot-side charge pipe nicely. I wonder if those would work on an R60..... It’s not listed in the fittment list, but a lot of R56 parts will or can be made to work on the Countryman. Same engine, same basic layout for most under hood parts.
Old Sep 24, 2018 | 06:55 PM
WayMotorWorks
Vendor
The Res delete hose on the R60 is actually shorter so you would have to cut and splice to make it work, so I just use our Res delete pipe as it just replaces the plastic part and will fit right.
https://www.waymotorworks.com/wmw-re...7-r58-r59.html
and the R60 has no noise maker so don't need to replace that hose.
Old Sep 25, 2018 | 07:42 PM
MrGrumpy's Avatar
MrGrumpy
Oh yeah, the hot side pipe I have already done the res delete. The other side is just fine. I was just thinking of matching the color to the blue one on the hot side.
dennyh
Dec 20, 2013 03:01 PM
Dead Ringer
R55 :: Clubman Talk (2008+)
Nov 21, 2008 09:40 AM
joshK
Jan 1, 2008 11:01 AM
