Drivetrain are there an cons using a turbo heat shield?
Old Aug 12, 2018 | 11:37 AM
brycewise11's Avatar
brycewise11
I know the benefit from using a turbo heat shield is under hood heat management.... does that create an issue because it increases temp of the turbo itself because it cant dissipate heat as well? or is it a non issue?
Old Aug 14, 2018 | 06:15 AM
Nader230's Avatar
Nader230
I was considering buying one, but then I came across this thread:
https://www.northamericanmotoring.co...ield-ever.html
Old Aug 20, 2018 | 05:13 PM
bugeye1031's Avatar
bugeye1031
Moderator
You might take a look at WMW's turbo blanket.....it does the job and your valve cover will not melt. I run one of his blankets, the OEM heat shield, and an NM shield for daily driving, autocrosses, and track days. The blanket is designed to hit our turbos....not a generic blanket.
Old Aug 20, 2018 | 05:29 PM
DneprDave's Avatar
DneprDave
Plus one on the Way Motor Works turbo blanket. a turbocharger is a heat engine, keeping the heat in it with lagging (insulation) is the best way to improve the efficiency of a turbocharger, it also helps keep the heat off of the rest of the turbocharger. you can expect a 20F temperature drop with the under hood temperature. the metal plate kind of heat shield, mostly just looks good.
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Old Aug 21, 2018 | 06:04 AM
mbwicz's Avatar
mbwicz
I'm another one for the 'more is better' approach. I ran a metal heat shield on my 08 for over 70k miles with no valve cover melting issues, because I retained the factory shield. I just installed a WMW blanket under the stock shield to try and control the heat better. I also installed a M7 metal shield over the top, mostly for aesthetics. So far, so good.
Mike
Mar 1, 2016 11:55 AM
kevjandon
Aug 29, 2013 06:29 AM
kevjandon
Sin City MINI Club (SCMC)
Aug 29, 2013 06:27 AM
rwkeating
Oct 30, 2007 09:59 PM
Robb's 07 Red MCS
Oct 20, 2007 03:53 AM
