Drivetrain 2007 r56 S engine swap to 09JCW engine
Old Aug 10, 2018 | 11:36 AM
William Chris Schuppert's Avatar
some may reamber my story I bout A 2007 mini S I only test drove it 6 mikes paid cash for it 20 miles from driving it off the car lot had a fatal engine Fail no lemon law applys
So I have a 4100 dollar yard ornament. I have a 09 JCW motor on the way with low miles.Since the turbo is larger how will the ecu respond?
will it be a issue? has any one else done this swap before?
any advice will be greatly appreciated .
Old Aug 10, 2018 | 11:59 AM
MarioKart's Avatar
MarioKart
Vendor
The turbo or lower compression won’t be an issue, but you won’t get the benefits of the turbo/motor with out a ECU tune.
I can help you and give you 40-100hp gain. You are more than welcome to email me at MarioPalza@gmail.com for more information
thank you and good luck
Mario
mQubed Motorsport Manic & RPM Power Tuning
Old Aug 10, 2018 | 12:52 PM
after market chip
aftermarket chip would do the trick in stead of remapping the ecu directly due to cost?
Old Aug 10, 2018 | 01:06 PM
MarioKart's Avatar
MarioKart
Vendor
no such chip. The ECU has to be mapped for that turbo. The gains are awesome and perfect daily drive ability
Old Aug 10, 2018 | 07:35 PM
after market chip
a after market race chip changes the mapping does it not? controls the same perimeters that a ecu program change does. Is my understating wrong?
what kind of money to get your ecu maped?
Old Aug 10, 2018 | 07:58 PM
MarioKart's Avatar
MarioKart
Vendor
trust me I have done well over 1000 Mini’s including my own. This is your true only solution
Old Aug 20, 2018 | 06:22 AM
jcwcoopster's Avatar
jcwcoopster
Did the Manic Stage II on my JCW and worth every penny. Mario can help you get the tune you want.
Old Aug 20, 2018 | 07:31 AM
bugeye1031's Avatar
bugeye1031
Moderator
^^^^ Mario did my tune...if he says he can help you, he can. There is no chip....the programming is in the ECU.
zzMini
Jun 30, 2008 05:52 AM
rimplestultskin
Cooper (non S)
May 13, 2008 06:59 AM
ninjlao
Dec 18, 2007 12:39 AM
BRGreen
Nov 18, 2007 12:06 PM
