Drivetrain R56 Engine Swap?
Old Nov 12, 2007 | 02:03 PM
ninjlao's Avatar
ninjlao
Ninja Mini
R56 Engine Swap?
Anyone attempt to swap the R56 engine into the R53?
Old Nov 12, 2007 | 03:32 PM
yellowbritishrocket's Avatar
yellowbritishrocket
im sure it could be done but im willing to bet the process involved would be extensive
Old Nov 12, 2007 | 03:50 PM
ninjlao's Avatar
ninjlao
Ninja Mini
would the r53 supercharger fit on the r56. The reason is because I jsut found out that the r56 is dohc.
Old Nov 12, 2007 | 03:57 PM
verveAbsolut's Avatar
verveAbsolut
Like anything in the auto world, it all comes down to cost.
So...
...yes, provided enough skill, engineering talent, and fabrication (by means of cash).
Now, has anyone done it yet, and/or done it with reasonable cost? No, and not likely to happen.
- Matt
Old Nov 12, 2007 | 04:30 PM
markjenn's Avatar
markjenn
It sounds like you're hunting for ways to swap parts or whole motors between the cars.
Just to be crisp, the R56 motor is a completely new clean-sheet design and doesn't share a single part with the R53. Under the hood, it's essentially a brand new car. So swapping of motors, superchargers is likely to be about the same work as swapping in a Honda or Toyota engine or other component... not impossible, but so far from a bolt-up operation, it's not remotely feasible unless you're a custom car builder.
- Mark
Old Nov 12, 2007 | 04:40 PM
'*Ace*''s Avatar
'*Ace*'
Do it...I just saw a R56 turbo engine on Ebay for 1k, came off a wreck...
Old Nov 13, 2007 | 12:06 AM
chuntington101's Avatar
chuntington101
is say hold on for a little while.
there will be LOTS of tuning stuff come out for these engines! the engine isant JUST used in the MINI but also in some cars over here in Europe to.
might still be cheaper to chop your car in for a R56 car though.
Thanks Chris.
Old Nov 13, 2007 | 12:33 AM
joshK's Avatar
joshK
Even if you could make it work, there are much better ways to get power out of an R56 motor than strapping a very adiabatically inefficient blower onto it.
Old Nov 13, 2007 | 12:57 AM
ninjlao's Avatar
ninjlao
Ninja Mini
- Mark
That is all I needed to know.
Some people like superchargers better than turbos. So its a matter of preference. I dont need your opinion on which one is more efficient or which one you like better.
Old Nov 13, 2007 | 09:05 AM
joshK's Avatar
joshK
If that's directed to me, what I said is fact, not an opinion and nowhere did I say which method I preferred.
Every method has an application to which it's best suited - you're more than welcome to spend the $$$ to do whatever you want, but in this particular application...other options will fare better.
Old Dec 1, 2007 | 10:17 AM
MINIotaple's Avatar
MINIotaple
In light of this thread, maybe we should revisit this idea... it's not a supercharger vs. turbo argument now...
Specifically this graph...
Old Dec 1, 2007 | 10:57 AM
MINIdriver85's Avatar
MINIdriver85
whoa, swapping the r56 turbo engine to an R53 would be cool...
Old Dec 18, 2007 | 12:39 AM
Trickle X's Avatar
Trickle X
You would pay more to do the swap then it would be to buy the daym 07 car then start to tune it......trust me on this...
Those numbers are nothing to get excited over....not for a swap....double them and then you may find it worthwhile, but even then......there are other viable options for pennies on that dollar...
danielbrookes_9
Oct 3, 2015 12:51 PM
makg
Aug 21, 2015 02:49 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:22 AM
