Drivetrain An eBay Intercooler review
Old Oct 29, 2018 | 05:56 PM
  #51
4mikebruns's Avatar
4mikebruns
NAM Community Team
Originally Posted by Jorge Perez
How about spooling up would it end up in a higher RPM? The black one linked above is out of stock sadly. I was digging that one.
doubtful. You should still get a fast spool
Old Oct 29, 2018 | 08:31 PM
  #52
cornjuice's Avatar
cornjuice
just a note - Amazon started carrying some of the same brand FMIC's for R56 as listed on Ebay..
Old Mar 8, 2019 | 09:33 AM
  #53
MidnightR55's Avatar
MidnightR55
Originally Posted by John_theCapn
http://r.ebay.com/wmO9Ga
Here y'all go.
The only downside I have had with it is that it's a little too think. That may not be a bad thing in the performance side of things....
It's a tight squeeze between the fascia cover and it. I had to poke a hole where the bolt goes through about 3/4 inch behind the stock one (bottom of plastic) in order for it to fit.
I am having the same issue, I have a 2009 JCW bumper. Did you get the bumper to line up ok?
Old Apr 25, 2019 | 10:42 AM
  #54
LittleS's Avatar
LittleS
Hey guys I have a r57 and went with the black Wagner knock off. I don’t have the bottom crash bar. After grinding off the top mounts and tab I was able to get it to fit but when putting the bumper back on the bottom fascia seems to run into the intercooler and doesn’t line up tight. So the bottom fascia kind of sticks out 3/4 inch and I can’t get all the bottom trim screws properly in. Do I have to remove the bottom center grill? Any tricks? Thanks.
Also I posted in another thread noticed less low rpm throttle response torque on otherwise stock setup. Anyone else notice? Longer turbo spool time?
Old Apr 25, 2019 | 11:09 AM
  #55
MidnightR55
I had the same fitment issue with my 2013 and with the Gplus intercooler. I ended up grinding down the support for the ambient temperature thermostat, as well as the lower grill of the bumper, including grill tabs at the bottom of the grim.
I used a dremmel and took my time with the grinding.
In regards to the lower tabs at the bottom of the bumper, as long as the bumper lines up, just drill some new holes to secure the bumper. Be careful when drilling because you don’t want to drill through anything else.
Take your time and do do it right. Good luck
Old May 3, 2019 | 06:38 AM
  #56
Beka_2JZ's Avatar
Beka_2JZ
Hello.
What app are you using To log data ?
Old May 3, 2019 | 07:14 AM
  #57
scotty_r56s's Avatar
scotty_r56s
Originally Posted by Beka_2JZ
Hello.
Data was collected via the Torque app for Android and the Carly for BMW OBDII bluetooth adapter, and then ported it into an excel spreadsheet.
