Drivetrain Manic stage 2 - what are the must haves?
Old Oct 15, 2017 | 10:13 AM
csllover's Avatar
csllover
Am not talking about the requirements (ie, uprated intercooler, colder spark plugs, decat d/p, uprated air intake) but things such as stiffer alta spring (for the dv?) or uprated clutch, uprated exhaust (min 2.5 inch), uprated hoses and so on. Would be interested to hear the forms thoughts on what to upgrade to make sure the engine runs smoothly.
Old Oct 15, 2017 | 05:19 PM
thebombardier's Avatar
thebombardier
The requirements are basically it. The Stage 2 tune is more or less the upper limit of the bone stock turbo and clutch. The engine will run fine and smooth, just keep on top of oil changes and regular maintenance.
I would definitely have some way of monitoring boost, AFR, intake temps, timing, etc. I use the DashCommand app on my iPod Touch with a WiFi OBD2 plugin and mount the iPod to my windshield. Gives me live readouts off all those things and more. I wouldn't be hammering it if your intake temps are above 100F. Also helps keep and eye on AFR in case you are running lean for whatever reason. Not much you can do about instantaneous lean conditions like if the fuel pump goes out but at least you can check to make sure the engine is regularly getting enough fuel.
Old Oct 16, 2017 | 03:42 AM
csllover's Avatar
csllover
Appreciate the reply. I had dashcommand since before but finally got round to using to check over some parameters. All fine it seems. However, I need to upgrade the clutch as it seems to on its last legs. Any thoughts on exhaust? So far I have the 2.5 decat downpipe with a custom resonator and standard cooper s muffler so might make sense to let the engine breathe a bit better.
Old Oct 16, 2017 | 04:58 AM
thebombardier
As far as bolt-on systems I like the Invidia Q300 for the price but it drones on the highway, adding a resonator to cut that out is ~$200 all said and done with labor.
If you're replacing the clutch anyway might as well do something that will hold more power like a JMTC or OS Giken. Username MarioKart on here is a JMTC dealer and can set you up with a clutch for your needs.
Old Oct 21, 2017 | 02:37 AM
csllover's Avatar
csllover
Thanks for your reply, will look into it.
(am a retard for not being able to embed the youtube video below....little help from a mod?)
Old Oct 21, 2017 | 02:41 AM
csllover's Avatar
csllover
Video of my latest dyno run:
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
