Drivetrain Throttle body mod?
Old Sep 22, 2004 | 05:05 AM
SpiderX's Avatar
SpiderX
Throttle body mod?
It has been suggested that I get a larger throttle body from stock. What do you notice when you do this. How is throttle modulation and idle etc affected? Any help is appreciated.
02 S, Unichip, 15% pulley, Borla exhaust, Dinan intake.
Old Sep 22, 2004 | 02:58 PM
polmear's Avatar
polmear
should only affect things after the throttle has opened. it allows a larger volume of air to pass. WOT you will certainly notice how much more power can be developed.
I'm sure I didn't cover everything, just a couple of basics; my knowledge is limited, so I try to only make comments I am pretty certain of.
Old Sep 22, 2004 | 04:28 PM
SpiderX's Avatar
SpiderX
I am looking for HP increase, throttle modulation difference etc. Anyone else?
Old Sep 22, 2004 | 08:37 PM
05JCWS's Avatar
05JCWS
SpiderX,
I would check out the Dinan, it is a pretty good price at $399. It should provide better throttle response and you should see a good 2-3hp in the higher rev range (I think +5,000 rpm). Helix noted this much hp when testing the throttle bodies.
I would be interested how this works in conjunction with someone who has larger injectors on.
Old Sep 22, 2004 | 09:23 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by dgszweda1
SpiderX,
I had heard from another MCS owner that the Dinan throttlebody is sold with the Dinan ECU software upgrade and not alone.
It's really unclear which size throttlebody will work best. There are now many sizes to choose from. Don't expect much HP gain although it is possible that throttle reponse might be a bit better than stock. There are no independent dyno comparisons yet.
Old Sep 23, 2004 | 05:20 AM
Redleg13's Avatar
Redleg13
Minihune: what kind of medicine do you practice that gives you the flexibility to see and respond to so many posts????
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
KinetechMW
Jan 22, 2016 09:04 AM
minimofo
Sep 20, 2015 05:17 PM
sempaipaul
Sep 9, 2015 05:55 PM
