Drivetrain Recirculation / Diverter Valve Upgrade
https://www.ecstuning.com/b-pierburg...658636606~pie/
I can confirm I ran this on mine, and you can see it’s for the n14, I carry one as a spare just in case. I put one on an n18 as well. I’m running a CTS BOV kit with no issues now.
Yep it works for n14 and n18 engines.
We just found O-ring that fits as an upgrade also. Or replacement.
This works for that main yellow/range o ring:
https://www.ecstuning.com/b-bremmen-.../1295n464~brp/
I picked up a CTS turbo “BOV” kit and I love it. I was run forgery spacer, new style dv, and Alta spring, which are now in the boot as a spare. I have had no issues since I swapped. I did blow out an old style while on the dragon, the fluttering it made gave it away, what a boring no boost 300 mile trip back home.
Welcome.
yep you can go with the updated design if you have the old one and solve two problems. Some peoprl that have the newer design and its older in age might pull it off for a other turbo repair and then need that gasket. So that works also.
No boost at the dragon is a slow day up the mountain
